Rear AC switch
Rear AC switch
Postby gejettest [OP] » November 24th 2010, 2:57am
Hello,
1996 GMC Safari, 230,000 miles, anyone have any problems with the rear ac switch? Mine felt a little rough going through the wheel motions, so I decided to take it apart. Found the electrical leads pins and sockets burnt. Is there a bulletin on this? Anyone have a common fix other than buy from the dealer?
On a side note, we have a 2006 Chevy Silverado 2500 as a company vehicle, the cab fan switch went dead. I did some research and sure enough this is a very common problem. Chevy says it isn't a recall because it is not a safety issue. According to some postings, fires have been reported along with strong burning smell. Sure enough, we took our electrical connector apart according to a Chevy S/B and there it was. The fix from Chevy is about 400-600 dollars. AutoZone has the connectors for about 70 dollars.
Henry
gejettest
Years of Membership: gejettest has been a member for 11 full yearsgejettest has been a member for 11 full yearsgejettest has been a member for 11 full yearsgejettest has been a member for 11 full yearsgejettest has been a member for 11 full yearsgejettest has been a member for 11 full yearsgejettest has been a member for 11 full yearsgejettest has been a member for 11 full yearsgejettest has been a member for 11 full yearsgejettest has been a member for 11 full yearsgejettest has been a member for 11 full years
Alias (AKA): gejettest
Van Model Year: 1996
Extra Info: 2wd 259k mi
  • Rear hatch lock switch
    by Rinny » May 5th 2020, 1:43am in Electrical
    July 8th 2020, 5:19am
  • Rear wiper switch button
    by Olivier02 » October 11th 2020, 8:34pm in Electrical
    Yesterday, 6:45pm
    23
    October 28th 2020, 5:59pm
Re: Rear AC switch
Postby Leeann_93 » November 25th 2010, 2:45am
It's common - across the years. My '93 has the same issue, though mine's a slider switch. I have a replacement pigtail (new) and a good used switch to swap into my van. Bought my AC Delco pigtail from rockauto.com.
Re: Rear AC switch
Postby gejettest [OP] » December 29th 2010, 7:49pm
Finally a thorough junkyard search yielded a used switch. Bonus is that this switch is a 'new replacement' that someone had spliced in. Great find, put it in, works great.
Attached are 2 photos of my original switch, complete with the burnt contacts.
Surprised it still worked, barely.
gejettest
It is currently October 28th 2020, 5:59pm
Time: 4:29am
Date: Oct 24 '20
Time: 3:02pm
donbenny1915
Date: Oct 23 '20
Time: 1:44am
nwisehart
Date: Oct 21 '20
Time: 12:44am
Olivier02
Date: Oct 11 '20
Time: 8:34pm
Users browsing this forum: No registered users and 17 guests
