No Dash cluster lights AT NIGHT !!!
Postby MR WUBBS [OP] » December 9th 2010, 6:54pm
I have checked ALL fuses and relays, seems my dash cluster lights do not work at night. They do work when the dimmer roller is turned on and the ceiling lights work as well at that time too.
I had a bad rear defogger switch the was replaced but that I do not think has any ties to the dash lights?
I can get the headlights and parking lights to operate on switch as normal but no dash cluster.
Could there be something inside the headlight/park light switch that has gone to sleep?
Thanks for any help
MR WUBBS
Years of Membership: MR WUBBS has been a member for 9 full yearsMR WUBBS has been a member for 9 full yearsMR WUBBS has been a member for 9 full yearsMR WUBBS has been a member for 9 full yearsMR WUBBS has been a member for 9 full yearsMR WUBBS has been a member for 9 full yearsMR WUBBS has been a member for 9 full yearsMR WUBBS has been a member for 9 full yearsMR WUBBS has been a member for 9 full years
Topics: 5
Alias (AKA): WUBBS
Extra Info: Stock AWD
Re: No Dash cluster lights AT NIGHT !!!
Postby Phantom » December 9th 2010, 7:28pm
MR WUBBS wrote:I seems my dash cluster lights do not work at night. They do work when the dimmer roller is turned on and the ceiling lights work as well at that time too.
Thanks for any help
They do work when the dimmer roller is turned on........but they don't work at night?
You referring to when you roll it all the way until it clicks and the dome light comes son?
Does that little button called the over ride do anything when pushed in both conditions when the dome light is on or off?
Phantom
Firing on 7 Cylinders (L4)
Postby jnbgoch » December 9th 2010, 7:40pm
I would say check all your fuses again. See my post below, I was having a similar problem. The fuse had a hairline break in it. :2:
jnbgoch wrote:FINALLY!!! Decided to take another look through the fuses. Turns out that fuse #9 in the under dash fuse box READS parking lights. It was blown and also operates all the lights I was having problems with. (tail lights, instrument lights, radio/overhead console, temp control) I found all this out by going through the fuse box again while reading the manual. Now all I have to do is get the cat. conv. changed and get smog tested!
Thanks to those who replied.
Brad
:doh:
(oYo) Chevy Astro LT
175,000 miles
jnbgoch
Fueling (7/8 tank)
Fueling (7/8 tank)
Years of Membership: jnbgoch has been a member for 11 full yearsjnbgoch has been a member for 11 full yearsjnbgoch has been a member for 11 full yearsjnbgoch has been a member for 11 full yearsjnbgoch has been a member for 11 full yearsjnbgoch has been a member for 11 full yearsjnbgoch has been a member for 11 full yearsjnbgoch has been a member for 11 full yearsjnbgoch has been a member for 11 full yearsjnbgoch has been a member for 11 full yearsjnbgoch has been a member for 11 full years
Topics: 7
Images: 8
Alias (AKA): Brad
Extra Info: LT
Postby MR WUBBS [OP] » December 9th 2010, 11:13pm
I was lucky to find another doner van today in a local junk yard..............I got the headlight switch for 20 bucs and installed it...............EVERYTHING WORKS !!!
I did in fact open the old switch and look what could be the problem, seems they use a anti corrosion grease to coat the tracks inside the switch...........I do not know if that in fact could cause the issue.
I will be getting the overhead console out of this van next week and all its wires as well. LUCKY FIND !!!!
THANKS FOR THE REPLYS
MR WUBBS
Topics: 5
Alias (AKA): WUBBS
Postby Phantom » December 9th 2010, 11:26pm
Glad to see you got it working, :thumbup: headlight switches draw a lot of current throughout the course of it's life , they get internal corrosion and go bad , not uncommon
Phantom
Postby RECox286 » December 10th 2010, 3:42am
Right on Phantom,
That can be said for just about everything electrical that goes bump in the night on these trucks. Amen.
Bob
RECox286
Purple Status (L6)
Purple Status (L6)
Topics: 40
Alias (AKA): Uncle Bob
Extra Info: RWD V6 [325K mi]
Postby mjlfinn » September 20th 2011, 3:30pm
Hi, I am wondering if your issue was the same as mine. I have a 2002 chevy astro van. my HVAC control switches along with the rear A/C, Heat, and wiper buttons are not lit. I did read somewhere about a headlight, headlamp, dimmer switch, etc... something like that that needs replaced. Are you talking about the module where I can turn the headlights on and off, or is there another switch/connector that you are talking about?
mjlfinn
Years of Membership: mjlfinn has been a member for 9 full yearsmjlfinn has been a member for 9 full yearsmjlfinn has been a member for 9 full yearsmjlfinn has been a member for 9 full yearsmjlfinn has been a member for 9 full yearsmjlfinn has been a member for 9 full yearsmjlfinn has been a member for 9 full yearsmjlfinn has been a member for 9 full yearsmjlfinn has been a member for 9 full years
Extra Info: 4.3L AWD
It is currently August 10th 2020, 12:00am
doogaloo
Comments: 13
Time: 8:52pm
Attached by: kittenflaps
kittenflaps
Comments: 18
Date: Aug 07 '20
Time: 12:46am
Sailing_Faith
Comments: 13
Date: Aug 06 '20
Time: 4:48pm
Attached by: bowtie262
bowtie262
Date: Aug 02 '20
Time: 8:41pm
Attached by: markmitch
Comments: 40
Date: Aug 01 '20
Time: 10:43pm
cron
