60 gal two stage compressor oil less or not??.
Postby Gary [OP] » February 10th 2011, 6:27am
In the coming wks I am going to be looking for a used 60 gal two stage compressor.I admit I am old school on this with a point of view that the oil less looks cheesy and not as good.
What aside from the oil less in the lines are the advantages and disadvantages of each type??.
Gary
Dearly Departed
Firing on 4 Cylinders (L3)
Topics: 136
Extra Info: high top
Re: 60 gal two stage compressor oil less or not??.
Postby RECox286 » February 10th 2011, 2:04pm
Hey Gary,
I've been fooling with air compressors since I was a teenager, now 64, and here's some of my 2 scents:
Oilless compressors run too fast to last as long as a good slow piston machine will that has oil and an intercooler to help dissapate the heat that builds up as the machine operates. I have a compressor that I built using an old refrigeration pump that was probably 30 years old when I found it, and it is still working well after 35 years of continual use at my garage.
On the other hand, when we got into the business of draining domestic water from vacation homes for the winter, we decided to go with oilless so there would not be any contamination of the water system, and the oilless was less bulky to carry around. Bad mistake. The price was right, but the machine only lasted a partial season before it literally burnt up, and we needed a replacement. I went back to a slow turning piston style that we continued to use for the next ten years or so. It is still working well, at my nephew's garage.
I would recommend that you get a machine that has oil in the crankcase, has two stages, turns around 500-600 RPM tops, incorporates an intercooler, is rated to NMT 175 PSI, has an unloader, cycles 170 psi OFF - 100 psi ON, and has the biggest air reservoir you can find. Nice but not necessary: automatic drain on the tank. Stay away from Chinese machines, they just will be junk before their time.
I don't know if you are looking for new or used, but I found the older used machines to be a good way to go if you are on a budget, and handy enough to do any repairs that they might need. Sometimes the only thing needed is to recondition the head of the compressor, change the belts, oil, tweek the electric parts (pressure switch). You know, the usual PM stuff.
If you have any other questions, give me a shout.
Bob
RECox286
Purple Status (L6)
Purple Status (L6)
Topics: 40
Alias (AKA): Uncle Bob
Extra Info: RWD V6 [325K mi]
Postby paintdrying » February 10th 2011, 4:57pm
I too am in the market for a compressor. I will just buy whatever off of craigslist. i do a lot of trim carpentery. One thing I can say about those chinese compressors is they are very quiet. For around 150 bucks I can get a new compressor, that is really light and quiet. I can also run my framer gun off it. I am not sure how long it will last, even if I get a year out of it I am happy , and would buy another one.
Those oilless craftsmen are fairly powerful and the last one I bought lasted 3 years running all day. Granted they are junk, however I sleep a little better at night knowing if someone steals it, no big deal. I love buying quality tools that will last a lifetime, but times are changing, if it will work use it. Also, make sure to drain the compressor everynight.
paintdrying
Years of Membership: paintdrying has been a member for 9 full yearspaintdrying has been a member for 9 full yearspaintdrying has been a member for 9 full yearspaintdrying has been a member for 9 full yearspaintdrying has been a member for 9 full yearspaintdrying has been a member for 9 full yearspaintdrying has been a member for 9 full yearspaintdrying has been a member for 9 full yearspaintdrying has been a member for 9 full years
Topics: 94
Extra Info: 108 000
Postby RECox286 » February 10th 2011, 9:12pm
The Oil-less type do have their place, however, that place is not in my shop. They are cheaper, I'll give you that with no arguement. If you are looking for a machine that will last the lifetime warranty (ha) go with the tried and true.
It seems that the diaphram compressors are everywhere, and the reason: price. They can be built as "direct drive" units where the motor is integral with the "cylinder". But, with the lack of the heavier duty parts, you will, as many owners do, place them on the scrap heap long before their piston counterparts. It is the throw away philosophy, they are cheaper to replace than repair. Being direct drive, they just run too damn fast, and create too much heat.
If you are using the compressor as a source for nailing, then yes, they will fit the bill nicely, because a gun is a very low air usage tool, the compressor need not be very large, or produce much volumn and only about 90psi tops. For the automotive shop, though, such a small, lightweight compressor will not keep up with the tools that are commonly used, which means that they are off and running again prior to letting the compressor cool between cycles. Some automotive tools will even run a well running shop system out of air, while the compressor labors.
Think of it in terms of grinding a V-8s' Starter Motor continuously for 5 minutes, letting it sit for only 30 seconds, and then having at it again. What are the chances of premature failure of the Starter ? They aren't made for that kind of abuse.
Selection criterion: Opt for the highest CFM (cubic feet/minute) @ 90 psi which is a standard specification for rating compressors. I would not consider a machine that has less than [email protected], and I would much rather see an average of [email protected] in order to satisfy the needs of grinders, air chisles, impact wrenches, blow guns, etc, but even a 20CFM machine will not keep up with a blasting media cabinet.
When working on a project it is rather a nuisance to have to "wait" for the compressor to catch up. Ideally, the compressor should be OFF, more than ON, or at least 50/50. Rather like using a compressor that one would find in an emergency kit in the trunk of the car for Inflating tires...20 or so minutes later, still buzzing.
I found an old "American Brake" shop compressor on the curb. I looked on the internet and found a valve rebuild kit. Had to replace the pressure switch, regulator, pressure gage and the drive belts.
The motor was frozen, so I took it apart to clean up the bearings and centrifugal starter switch and give it a little grease here and there. Changed the oil in the compressor, and made an airfilter because the original was missing. I put a smaller drive sheave on the motor, so that the compressor would go slower than designed. It is a 2 stage with intercooler, and sounds like a little sewing machine when it is running. It sits on a 30 or 40 gallon tank, and will pressurize from 0 to 175psi in about 5 to 6 minutes I only spent about $50 in all, plus a couple of hours of my time, for a machine that, if new, would cost in the neighborhood of $1500. Not a bad find.
Bob
RECox286
Purple Status (L6)
Purple Status (L6)
Topics: 40
Postby chevymaher » February 11th 2011, 12:46am
This one has not been made in 32 years I got it off craigslist eighty bucks three years ago.Reed valves were clogged a little parts washer soaking .Has not given me any problem in three years Ive had it.Eighty gallon storage tank hooked to that .I found a formula for acfm online and it puts out 14.75.So evrybody show pics of yours.There good deals if your lookin for them
Postby webcat » February 11th 2011, 1:09am
chevymaher wrote:This one has not been made in 32 years I got it off craigslist eighty bucks three years ago.Reed valves were clogged a little parts washer soaking .Has not given me any problem in three years Ive had it.Eighty gallon storage tank hooked to that .I found a formula for acfm online and it puts out 14.75.So evrybody show pics of yours.There good deals if your lookin for them
Thats a really nice one , yeah belt driven is the way to go :thumbup:
You have a sound clip of that baby :lol:
webcat
Firing on 3 Cylinders (L3)
Topics: 253
Alias (AKA): Larry aka Rambo
Extra Info: g10 5.7L vortec
Postby chevymaher » February 11th 2011, 2:05am
.Its little motorcycle engine sound.I used a high amperage switch with ground disconnect so it runs off a light looking switch on the cieling.That babies whole purpose was painting the van years ago when it got smacked the first time.It is handy sanders chisels impact I dont know how I did without so long.I take my phone down now see if I can U tube it.
Postby chevymaher » February 11th 2011, 2:31am
It a sound bite it to dark in corner to see it at night all the light in front of van.
Postby Leeann_93Leeann_93 is online! » February 11th 2011, 2:55am
I've got a Dayton Speedaire, 20 gal 2 hp horizontal compressor - oil bath type, 240v. Got it free along with an ugly van that I've since sold. Sucker just keeps thumpin' along. I thought I had a pic but I can't find it now; I'll take one later.
Postby webcat » February 11th 2011, 3:08am
Leeann_93 wrote:I've got a Dayton Speedaire, 20 gal 2 hp horizontal compressor - oil bath type, 240v. Got it free along with an ugly van that I've since sold. Sucker just keeps thumpin' along. I thought I had a pic but I can't find it now; I'll take one later.
Leanne , is this it ?
found it google image
webcat
Topics: 253
Postby Leeann_93Leeann_93 is online! » February 11th 2011, 3:25am
That's newer than mine. Mine looks more like this
I've got a 3Z419B.
Postby chevymaher » February 11th 2011, 3:41am
Leeann_93 wrote:That's newer than mine. Mine looks more like this
I've got a 3Z419B.
Is that a 2 or three cylinder one LeAnn my buddy got one like that and it 3 cylinder.An old sears one.
Postby Leeann_93Leeann_93 is online! » February 11th 2011, 3:56am
I've gotta look again, but I think it's a 2 cyl.
EDIT: yup, a 2cyl.
Specs from the specs, performance & parts list:
2 HP, 2 CYL, 10.5 CFM 6.2 CFM Free Air @ 100 PSI, 750 RPM, 20 gal, 2¾" bore, 2" stroke, max work pressure 125 psi
Postby RECox286 » February 11th 2011, 5:44am
Hey Leeann,
That is a classic ! Give it an oil change and clean the air filter about once a year or two, and that "beast" will probably outlast you. Speedaire is a respected name in the business. Parts can still be had for practically ALL their stuff, from Grainger, or Speedaire direct.
Chevymaher,
These older compressors just don't want to die. You might want to think about putting some sort of a cover on that pressure switch to keep little fingers out of harms' way.
Bob
RECox286
Purple Status (L6)
Purple Status (L6)
Topics: 40
Postby chevymaher » February 11th 2011, 6:31am
RECox286 wrote:Hey Leeann,
Chevymaher,
Bob
It got a cover on it That picture is real old when I was wiring house for the 220 and putting it in.Covers just off in picture.And I did the me thing to get the CFM it 30% overdriven.
Postby Leeann_93Leeann_93 is online! » February 12th 2011, 12:01am
Got the pics...here you go. Obviously, I need to clean it and do some rust reformation...and it's time for an oil change, too.
I've got 100' of hose on a hose reel that pulls straight out the basement steps to outside. It's perfect - the driveway is 10' away.
Postby chevymaher » February 12th 2011, 1:19am
Thats nice LeAnn that was what kind I almost got.But they were more expensive than one I got because it was clogged and would not hold pressure.A oil and dirt mix in the reed valves and they dont sell parts so they thought it was junk.And I jealous you got a hose reel.I got three outlets around garage but keep my hoses rolled up hanging from nail on cieling.
Postby Leeann_93Leeann_93 is online! » February 12th 2011, 1:56am
I got lucky. We paid $1500 for the van and got the air compressor, a console humidifier, 4 Michelin LTX M+S tires mounted on nice Dodge rims and 1 MIchelin other tire on a spare rim (235/75/R15 - that's what I put on the Bravada for the first 2 years), an engine crane, an engine stand, an old Craftsman drill press, a 12 ton shop press (those 4 went to the bf's brother's shop since he has room for them), umm...there were a couple other things but I can't remember now.
Used the van for 4 years - B250 with a 360 and tow package - and sold it for $750. Used the tires for 2 years until they dry-rotted. The tools are still in use in his brother's shop, the console humidifier is in use every day in the winter in my house and the compressor is in constant use. Not so bad, huh?
I bought the hose reel from Grizzly Industrial online. It was on sale pretty cheap (I wanna say under $30) since it's hand-crank. The hose is two 50' lengths with a coupler, bought at Lowe's. We have a filter/dryer we haven't installed yet, but really need to.
Postby chevymaher » February 12th 2011, 2:46am
Leeann_93 wrote:I got lucky. We paid $1500 for the van and got the air compressor, a console humidifier, 4 Michelin LTX M+S tires mounted on nice Dodge rims and 1 MIchelin other tire on a spare rim (235/75/R15 - that's what I put on the Bravada for the first 2 years), an engine crane, an engine stand, an old Craftsman drill press, a 12 ton shop press (those 4 went to the bf's brother's shop since he has room for them), umm...there were a couple other things but I can't remember now.
That a heck of a deal for sure.Bought the tools and they threw in a van to take them away in.I got a moisture trap on one line but I only use it when I paint.Pressure regulator/Trap combo deal.I draw my tool air from top of second tank so I dont get alot of moisture in line.Just give my tools a shot of lube everytime I use them.
Postby Gary [OP] » February 12th 2011, 5:28am
Having read what people said confirms what I was thinking.No oil less for me.The next compressor I will be looking for used will be a belt driven two stage 60 gallon horizontal tank.I owned a 120 gallon vertical tank that even shimming it towards the drain,I couldn't get as much water out of that as the horizontal ones.It will be a 220 powered motor.The two stage is for the CFM for body tools like board sanders,sand blasters,ect that are known to need a high CFM rating.
Gary
Dearly Departed
Topics: 136
Return to Uncategorized
It is currently October 29th 2020, 12:58am
Uncategorized Forum
Moderators: Leeann_93Leeann_93 is online!, icebrrg3rd
in Uncategorized
Comments: 16193
Date: Oct 27 '20
Time: 4:45pm
in Uncategorized
Comments: 16193
Date: Oct 26 '20
Time: 4:38pm
in Uncategorized
Date: Oct 26 '20
Time: 2:13pm
joeg
in Uncategorized
Date: Oct 23 '20
Time: 10:10pm
joeg
in Uncategorized
Date: Oct 23 '20
Time: 10:08pm
