It's been stumbling off the line, no accelleration till 3rd gear,
once in a while even engine dies while idling at a stop light.
The kind of thing that feels like a vacuum leak.
Engine code 14 (lean, read at O2 sensor).
Gas tank was down near empty. Gas in the tank was 90 days old,
top tier Shell regular.
Guessing that perhaps the gas had gotten old...
I filled the tank (top tier Shell reg again), took 20.5 gallons in it's
tank which I think(?) is 27 gallons.
It IMMEDIATELY ran better. No more stumble, accelleration was
fine etc. It was so immediate it was like as I pulled away from the
gas pumps.
So I'm thinking it wasn't BAD gas, it may have simply been NO gas,
ie the fuel pump pickup was sucking air. If it was bad gas, I'm thinking
it would have taken a few miles to work it's way from tank to engine.
In any case, the camo van is rollin again...
You played on "The Love Boat"?
Yes. White tux, huge sideburns.
http://www.LumpyMusic.com
