Van likes to go 30 MPH before it warms up.
Postby deafman [OP] » February 21st 2017, 1:59am
Not sure what topic this goes under, almost went with engine.
This Is Not A Priority.
The van goes too fast after a cold start.
It will go up to 25-30 MPH all by itself for a couple of miles.
It does not accelerate crazy fast like when on cruise control after you have slowed down and hit resume.
It's more like too fast at first and smoothly gets faster until peaking out at 25-30 MPH after going about 1/3 of a mile.
It builds up to that speed and holds it all by itself like it is on a really slow and even resume for cruise control.
All you have to do is put it in gear
I tried lifting the accelerator with my toes and it ignores that. :violence-captureflagblue:
After a couple miles it gets normal.
Or at least after my first stop/restart a couple of miles away.
So it seems like when it gets to operating temp everything acts as it should.
I don't feel in danger but I am sure that my brake$ are working harder.
I live in a small town but if I was in stop and go traffic it would be wanting to go faster than needed.
Could this be idle air control valve or some sensor ?
Throttle need some attention ?
I can't hear it but it feels like it idles all right.
People have said that it sounds good.
But there have been no witnesses while she is doing the morning sprint.
They only hear it after I have driven it awhile.
The only code that I have is P0440 EVAP System No Flow During Purge.
The light came on after getting a full tank with the pump on auto.
I don't remember giving it a shot extra but may have.
Not worried about it after reading up on it.
And the problem that I am posting about existed before this happened.
I bought the van on Halloween could it have become demon possessed somehow ?
Is there some old rule about not swapping titles on Pagan holidays ? :shrug: :angry-devil:
I can research this problem more but I thought that some of you hot shot mechanics might know what it is of the top of your head. :shrug:
At least it doesn't run too slow. :auto-layrubber:
Edit : It's a 2002 Rear Wheel Drive.
And it is not an intermittent problem.
It does go away at operating temps.
But every cold start she wants to run fast.
deafman
Years of Membership: deafman has been a member for 4 full yearsdeafman has been a member for 4 full yearsdeafman has been a member for 4 full yearsdeafman has been a member for 4 full years
Van Model Year: 2002
Extra Info: LS RWD
Re: Van likes to go 30 MPH before it warms up.
Postby chevymaher » February 21st 2017, 2:32am
Clean check the IAC Valve it sounds like it is opening for start up and getting stuck.
Topics: 91
Postby deafman [OP] » February 21st 2017, 2:35am
Thanks Chevymaher,
I was hoping that you might have an idea.
deafman
Extra Info: LS RWD
Postby The Drummer » February 21st 2017, 2:47am
Look for codes , when the coolant temp sencor went south on mine , it would idle way too fast after warm up , but it was hard to start and would flood it self as well ,also make sure you have no vacuum leaks ,dunno just an idea .
''USE THE TORQUE LUKE ''
and beware of trees ,them nasty wooden things are evil .
The Drummer
Years of Membership: The Drummer has been a member for 9 full yearsThe Drummer has been a member for 9 full yearsThe Drummer has been a member for 9 full yearsThe Drummer has been a member for 9 full yearsThe Drummer has been a member for 9 full yearsThe Drummer has been a member for 9 full yearsThe Drummer has been a member for 9 full yearsThe Drummer has been a member for 9 full yearsThe Drummer has been a member for 9 full years
Topics: 16
Images: 49
Extra Info: SLT 4.3 AWD
Postby WimpTech » February 21st 2017, 6:58pm
... missing thermostat?
WimpTech
Firing on 4 Cylinders (L5)
Topics: 38
Images: 322
Alias (AKA): =Wimpy=
Extra Info: AWD 3+1 Lift
Postby 97cargocrawler » February 21st 2017, 7:12pm
Sounds like a great time for some R&R on the throttle body. Replace the IAC, make sure the spring and cam on the side move free, check the cable for binding, look for vacuum leaks, scrub the black tar off the butterfly, etc.
Make sure it looks something like this when you're done:
(I'm recycling all my old pix today, yay!)
97cargocrawler
Topics: 42
Alias (AKA): KING OF OVERKILL
Postby zach914v8 » February 21st 2017, 7:15pm
97cargocrawler wrote:Sounds like a great time for some R&R on the throttle body. Replace the IAC, make sure the spring and cam on the side move free, check the cable for binding, look for vacuum leaks, scrub the black tar off the butterfly, etc.
:clap:
My Rides:
1974 Porsche 914 powered by a 305 Chevy v8.
1994 GMC Safari TBI 4.3, Lifted 4"
zach914v8
Years of Membership: zach914v8 has been a member for 11 full yearszach914v8 has been a member for 11 full yearszach914v8 has been a member for 11 full yearszach914v8 has been a member for 11 full yearszach914v8 has been a member for 11 full yearszach914v8 has been a member for 11 full yearszach914v8 has been a member for 11 full yearszach914v8 has been a member for 11 full yearszach914v8 has been a member for 11 full yearszach914v8 has been a member for 11 full yearszach914v8 has been a member for 11 full years
Topics: 12
Alias (AKA): ballzach
Extra Info: 4 inch lift
Postby WimpTech » February 21st 2017, 7:21pm
.... show off
WimpTech
Topics: 38
Images: 322
Postby AstroWill » February 21st 2017, 7:26pm
It's even smiling :) I would too.
Images: 473
Postby deafman [OP] » February 21st 2017, 7:52pm
:rofl: :rofl: :rofl:
:ty:
deafman
Extra Info: LS RWD
Postby Lumpy » February 21st 2017, 8:50pm
Ask her to hold up those dual AC pumps.
Postby astro_dude » February 22nd 2017, 1:07am
It looks...
AMAZING!
astro_dude
Years of Membership: astro_dude has been a member for 4 full yearsastro_dude has been a member for 4 full yearsastro_dude has been a member for 4 full yearsastro_dude has been a member for 4 full years
Postby WimpTech » February 22nd 2017, 1:09am
...yes they do!
ohh, ummm, is she holding...something...???
WimpTech
Topics: 38
Images: 322
Postby WoodButcher » February 23rd 2017, 1:17pm
Second time in 2 minutes I'm talking about my ex,
I'd recognize her anywhere.
It figures she's holding someone else's throttle body.
What confuses me is how a young guy like CC, way across the country got her photo? She went to SF before we met but in the early eighties I think Jack was still in short pants. :shrug:
WoodButcher
Firing on 5 Cylinders (L6)
Topics: 30
Images: 514
Alias (AKA): Bruce
Extra Info: 5.7L RWD
Postby RVMAN » February 23rd 2017, 3:29pm
Uhhmmmm errr where can I get me wanna them Throttle Body Holders?
I'll pay for overnight shipping and any other fee's....
RVMAN
Years of Membership: RVMAN has been a member for 5 full yearsRVMAN has been a member for 5 full yearsRVMAN has been a member for 5 full yearsRVMAN has been a member for 5 full yearsRVMAN has been a member for 5 full years
Alias (AKA): Ray
Postby Lumpy » February 23rd 2017, 4:59pm
Foothill and Rosemont.
Postby RVMAN » February 23rd 2017, 5:08pm
how far from Dothan Alabama?
RVMAN
Alias (AKA): Ray
Postby Lumpy » February 23rd 2017, 5:17pm
Roughly eleven.
Postby ccookie66 » February 23rd 2017, 7:33pm
Thats a clean throttle body! :thumbup: :dance: :mrgreen:
1160
The Astro is always a turn key away from adventure.
ccookie66
Firing on 6 Cylinders (L2)
Years of Membership: ccookie66 has been a member for 9 full yearsccookie66 has been a member for 9 full yearsccookie66 has been a member for 9 full yearsccookie66 has been a member for 9 full yearsccookie66 has been a member for 9 full yearsccookie66 has been a member for 9 full yearsccookie66 has been a member for 9 full yearsccookie66 has been a member for 9 full yearsccookie66 has been a member for 9 full years
Topics: 139
Images: 73
Alias (AKA): Cameron
Extra Info: 4.3L V6 TBI Shorty
Return to Uncategorized
It is currently April 13th 2021, 1:41am
Uncategorized Forum
in Uncategorized
Comments: 3022
Date: Apr 11 '21
Time: 3:28am
in Uncategorized
Comments: 24
Date: Apr 11 '21
Time: 12:09am
in Uncategorized
Comments: 24
Date: Apr 10 '21
Time: 11:48pm
in Uncategorized
Comments: 16490
Date: Apr 09 '21
Time: 5:03pm
backinabox
in Uncategorized
Comments: 16490
Date: Apr 08 '21
Time: 2:31am
Users browsing this forum: Google [Bot] and 18 guests
