Annual inspection passed
Postby Astrocurious [OP] » August 27th 2017, 3:37pm
It's been a case of bad news, good news, bad news and more good news over the last couple of months.
My voltage gauge was fluctuating quite a lot and the van gave up with a flat battery as I tried to pull away from a petrol station.
The problem turned out to be a poor connection with the battery warning light in the dashboard. Alternators need a 12v supply to start the charging process and this runs through the dashboard warning light. Some alternators only need this supply on startup and some need a constant supply. All is fixed now and we are happily charging.
It was also MOT time (ministry of transport annual inspection) so the van was cleaned up and sent in a month early. A lot of last years advisories were sorted out by the previous owner but the brake pipes were still rusty for the fourth year running. This is probably why the main pipe behind the petrol tank split while the van was being tested! I felt really bad because there was a lot of brake fluid pouring all over the testers nice clean floor.
I was intending to replace the pipes after the MOT but was waiting just in case there was a major issue. This forced my hand and the van was limped over to the garage next door. I thought this would be a good chance to clear all of the advisories so I asked the garage to replace both ball joints (one was a failure anyway) replace the drag link and replace all of the brake pipes.
They worked hard and got most completed. The ball joints were the originals and were a sod to get out. The drag link was replaced and all but the front brake pipes were replaced as the bleed nipples on the calipers looked a bit too crusty. I didn't have time to order new ones so they were left to me to do. I will either order a new set of bleed screws or treat the van to some new calipers.
This looks much better.
I am really pleased, the van has covered around 4500 miles this year in complete comfort. There are still niggles which I will try to sort out over the next few months which will keep it going even further.
Astrocurious
Years of Membership: Astrocurious has been a member for 4 full yearsAstrocurious has been a member for 4 full yearsAstrocurious has been a member for 4 full yearsAstrocurious has been a member for 4 full years
Images: 72
Van Model Year: 1996
Extra Info: Mirage conversion
  • Mechanic for Pre-Purchase Inspection? (Riverside, CA)
    by Pizzabard » February 9th 2021, 9:08pm in Uncategorized
    Last post by WinnieVan View the latest post
    February 9th 2021, 9:11pm
    31
    April 13th 2021, 10:49pm
Re: Annual inspection passed
Postby AstroWill » September 10th 2017, 6:56pm
Glad to hear you passed! Always something else to fix though.
Images: 473
Return to Uncategorized
It is currently April 13th 2021, 10:49pm
Uncategorized Forum
Attached by: chevy57bert
chevy57bertchevy57bert is online!
in Uncategorized
Comments: 3025
Date: 3 minutes ago
Time: 10:45pm
rozmpattersonrozmpatterson is online!
in Uncategorized
Comments: 3025
Date: Today
Time: 5:38pm
Attached by: icebrrg3rd
icebrrg3rd
in Uncategorized
Comments: 16491
Date: Today
Time: 4:34am
in Uncategorized
Comments: 3025
Date: Apr 11 '21
Time: 3:28am
in Uncategorized
Comments: 24
Date: Apr 11 '21
Time: 12:09am
Users browsing this forum: Yandex [Bot] and 11 guests
