Anyone tried fuel pump repair kit rather than complete pump?
Postby dcarlson12 [OP] » August 12th 2008, 7:03pm
I see these repair kits advertised on ebay:
http://cgi.ebay.com/ebaymotors/FUEL-PUM ... enameZWD1V
Has anyone tried these rather than a complete new pump? If so, what results?
The cheapest I can find a pump mu1375 for 2000 Chevy Astro is at a place called rockauto.com
http://www.rockauto.com/dbphp/mfr,ACDEL ... uel%2BPump
for $260.89
Has anyone bought from them? And is it truly an OEM i.e. AC Delco pump?
Has anyone found it cheaper elsewhere?
Thks,
Dwight
PS I see there is an assembly part#mu1380 which seems to be similar but is "w/ROBUST FUEL SYS SENDER(K53)" but I believe the mu1375 has a sending unit for fuel level. Anyone know the difference or use one versus the other?
dcarlson12
Fueling (1/2 tank)
Fueling (1/2 tank)
Years of Membership: dcarlson12 has been a member for 12 full yearsdcarlson12 has been a member for 12 full yearsdcarlson12 has been a member for 12 full yearsdcarlson12 has been a member for 12 full yearsdcarlson12 has been a member for 12 full yearsdcarlson12 has been a member for 12 full yearsdcarlson12 has been a member for 12 full yearsdcarlson12 has been a member for 12 full yearsdcarlson12 has been a member for 12 full yearsdcarlson12 has been a member for 12 full yearsdcarlson12 has been a member for 12 full yearsdcarlson12 has been a member for 12 full years
  • Anyone here ever tried this companies products?
    by markmitch » June 12th 2020, 9:06pm in Electrical
    June 18th 2020, 12:35am
  • Anyone ever tried these?
    by markmitch » November 15th 2020, 2:11am in Uncategorized
    71
    December 4th 2020, 5:54pm
Re: Anyone tried fuel pump repair kit rather than complete pump?
Postby ScottS » August 14th 2008, 11:11pm
The "Robust fuel level sensor" is probably a gold alloy to protect against the effects of sulfer in the fuel.
1995 Safari AWD
1998 Safari AWD
ScottS
Fueling (5/8 tank)
Fueling (5/8 tank)
Years of Membership: ScottS has been a member for 12 full yearsScottS has been a member for 12 full yearsScottS has been a member for 12 full yearsScottS has been a member for 12 full yearsScottS has been a member for 12 full yearsScottS has been a member for 12 full yearsScottS has been a member for 12 full yearsScottS has been a member for 12 full yearsScottS has been a member for 12 full yearsScottS has been a member for 12 full yearsScottS has been a member for 12 full yearsScottS has been a member for 12 full years
Alias (AKA): ScottS
Postby f4plt » April 12th 2014, 6:50pm
Dwight,
I am replacing the fuel pump on my 2000 Astro -- quantity sending unit has failed. Pump is otherwise in working order (I am the original owner, vehicle has 98,000 miles). If you want to take a chance on this, you can most likely find a fuel quantity repair kit for less than $20 (or use your old one). Will sell for $50 bucks plus shipping costs if you're interested. Side note: I haven't been able to get the unit out of the tank yet; the lock ring won't budge. Ordered up special tool J-39765, you may need that too, although most seem to get the job done with a drift and a hammer. That didn't work for me -- I left the tank in the van, and cut an access hole in the floor, then will install a 10" marine deck plate. Good luck to you on this one - it's not as easy as I expected. Ron
f4plt
Years of Membership: f4plt has been a member for 6 full yearsf4plt has been a member for 6 full yearsf4plt has been a member for 6 full yearsf4plt has been a member for 6 full yearsf4plt has been a member for 6 full yearsf4plt has been a member for 6 full years
Return to Uncategorized
It is currently December 4th 2020, 5:54pm
Uncategorized Forum
Attached by: xit
xit
in Uncategorized
Comments: 16281
Time: 4:15pm
foxfire
in Uncategorized
Comments: 16281
Date: Nov 30 '20
Time: 2:25am
Attached by: chevymaher
in Uncategorized
Date: Nov 28 '20
Time: 5:28pm
in Uncategorized
Date: Nov 28 '20
Time: 4:01pm
in Uncategorized
Comments: 16281
Date: Nov 27 '20
Time: 6:33pm
Users browsing this forum: No registered users and 17 guests
