Headlight adjustment
Postby Shad0wXCalibur [OP] » December 3rd 2011, 8:30am
Does anyone know which adjustment screw on the 2nd gen composite headlights adjusts it up and down? Found two pics in an old thread but it doesn't say which one adjusts what.
These are the pics.
1987 Astro
2000 Safari
Shad0wXCalibur
Years of Membership: Shad0wXCalibur has been a member for 9 full yearsShad0wXCalibur has been a member for 9 full yearsShad0wXCalibur has been a member for 9 full yearsShad0wXCalibur has been a member for 9 full yearsShad0wXCalibur has been a member for 9 full yearsShad0wXCalibur has been a member for 9 full yearsShad0wXCalibur has been a member for 9 full yearsShad0wXCalibur has been a member for 9 full yearsShad0wXCalibur has been a member for 9 full years
Topics: 41
Extra Info: Lifted 2wd
  • Headlight cleaning and/or replacing
    by AstroOafAdventurer » August 29th 2020, 6:37pm in Exterior
    October 28th 2020, 1:20am
  • LED Headlight Replacement-Safari
    by BobbyD » September 5th 2020, 10:08pm in Exterior
    Last post by joeg View the latest post
    September 16th 2020, 10:02pm
    December 3rd 2020, 11:21am
Re: Headlight adjustment
Postby Leeann_93 » December 3rd 2011, 4:19pm
The E-Torx in the first pic.
Postby Phantom » December 3rd 2011, 5:21pm
In the pic
Item 5 is ADJUSTER HDLP VERT,(LH & RH)
Item 17 is ADJUSTER HDLP HORIZ
Gen2 Composite headlights .png (23.92 KiB) Viewed 4568 times
Phantom
Firing on 7 Cylinders (L4)
Postby Shad0wXCalibur [OP] » December 3rd 2011, 8:45pm
Thanks!
1987 Astro
2000 Safari
Shad0wXCalibur
Topics: 41
Postby Bis » May 30th 2015, 2:15am
Trying to adjust my right headlight (Y-axis) and this torx screw won't turn. I am afraid I am going to strip the head...
:banghead: :screaming: :think:
✔ Recovering 3-Time ex-Aerostar owner since 1996.
✔ RC Hobbyist and Dance music nut.
✔ Geeky Astroholic.
ツ Glad to be of help! ツ
Bis
Years of Membership: Bis has been a member for 9 full yearsBis has been a member for 9 full yearsBis has been a member for 9 full yearsBis has been a member for 9 full yearsBis has been a member for 9 full yearsBis has been a member for 9 full yearsBis has been a member for 9 full yearsBis has been a member for 9 full yearsBis has been a member for 9 full years
Topics: 30
Alias (AKA): Bis
Extra Info: LS 4.3L V6 RWD
Postby Leeann_93 » May 30th 2015, 2:44am
If you've sprayed the hell out of it with PB Blaster and it still won't turn, take the assembly off the vehicle and srpray the back of the screw and try again.
If that doesn't get it loose, spray the hell out of it and apply a little heat. If that doesn't work, look for a used headlight assembly.
Postby Lumpy » May 30th 2015, 2:48am
Heat it (soldering gun). Cold it (FreezeOff or canned duster for keyboards [shake the can]). Heat or cold the thing that holds the bolt, do the opposite to the bolt.
Postby Bis » May 30th 2015, 4:01am
WD40 and the "impact" setting on my electric driver at low torque did the job without stripping anything.
I tell ya, this power tool is making my life so much easier!!!
Thanks guys for the advice! The tan girl now has new lights!
✔ Geeky Astroholic.
Bis
Topics: 30
Alias (AKA): Bis
Postby triggr » August 4th 2016, 2:43pm
Thanks for the tips..I gotta adjust mine too. I'm glad this site is active..
triggr
Years of Membership: triggr has been a member for 4 full yearstriggr has been a member for 4 full yearstriggr has been a member for 4 full yearstriggr has been a member for 4 full years
Alias (AKA): trigger
Van Model Year: 2002
Extra Info: LS RWD
Return to Uncategorized
It is currently December 3rd 2020, 11:21am
Uncategorized Forum
foxfire
in Uncategorized
Comments: 16275
Date: Nov 30 '20
Time: 2:25am
Attached by: chevymaher
in Uncategorized
Date: Nov 28 '20
Time: 5:28pm
in Uncategorized
Date: Nov 28 '20
Time: 4:01pm
in Uncategorized
Comments: 16275
Date: Nov 27 '20
Time: 6:33pm
Attached by: icebrrg3rd
icebrrg3rd
in Uncategorized
Comments: 16275
Date: Nov 24 '20
Time: 5:55pm
cron
