a few questions for you guru's
Postby markmitchmarkmitch is online! [OP] » November 1st 2019, 3:19pm
I just picked up a 1994 Astro it has the 4.3 and 4l60E and the air bag in the steering column.
How much work to swap in a 700R4 later
is the wiring harness much different to swap in a 7747 pcm do I need to change harnesses to do both? and what do i need to do to swap the air bag steering wheel out to install my Grant custom whel with out air bag?
I am considering using my 89 as a part vehicle just because I can get it smogged with the V6 then later add my V8 since the county I live in does not require smogged after its legal once. :ty: :ty: Mark
Firing on 7 Cylinders (L6)
Topics: 622
Images: 20
Extra Info: RS V8 AWD
Re: a few questions for you guru's
Postby jeff's93astro » November 1st 2019, 6:07pm
I can't answer for any small changes but it'll involve computer and harness swap for trans.
As for air bag column I tried a steering wheel swap in my 95 but inside the column is totally different. But i swapped in a 89 column and it was a direct swap so id recommend swapping column
95 Astro 5.3L RWD 3/3 drop
03 Suburban 5.3L 2wd 3/5 drop
jeff's93astro
Topics: 55
Images: 19
Extra Info: CS 4.3L V6 RWD
Postby Mmusicman » November 1st 2019, 7:21pm
The 700R4 can be operated completely WITHOUT a controller.
The only controlled device in it is the lock-up converter, which can easily be manually switched.
I run my stock 700R4 (in my 92) behind my carbureted V8.
As far as controlling an air-bag... I HAVE NO IDEA!
I sport a Grant wheel in my 92 (with no airbag)
Firing on 7 Cylinders (L5)
Topics: 73
Images: 49
Postby jeff's93astro » November 1st 2019, 8:03pm
I also forgot they make a hydralic lock up kit for the 700 and that gets rid of the electrical and it'll lock up automatically or do like musicman and manually do it
jeff's93astro
Topics: 55
Images: 19
Postby markmitchmarkmitch is online! [OP] » November 2nd 2019, 12:31am
Just when you think you know your wife she says Oh I think we should keep both Astro's cause the blue one(the 94 I just got) is bigger and has two bench seas for our dogs lol. So instead of building the 94 i am just gonna fix it up a bit such as a distributor swap touch up the paint and a tune up. Seems the electrical problem is the distributor. So we are now a two Astro family! Thanks for the replies guys.
Topics: 622
Images: 20
Return to Uncategorized
It is currently January 19th 2021, 3:10am
Uncategorized Forum
Moderators: Leeann_93Leeann_93 is online!, icebrrg3rd
Rockridge
in Uncategorized
Comments: 2977
Date: Today
Time: 12:03am
Ram
in Uncategorized
Date: Jan 17 '21
Time: 6:51pm
in Uncategorized
Comments: 16380
Date: Jan 14 '21
Time: 3:29am
tungtide
in Uncategorized
Comments: 16380
Date: Jan 11 '21
Time: 12:08am
Attached by: AlpineVan
AlpineVan
in Uncategorized
Comments: 234
Date: Jan 09 '21
Time: 12:19am
Users browsing this forum: Leeann_93Leeann_93 is online! and 8 guests
