by Brewtus [OP] » December 25th 2019, 9:29am
by Brewtus [OP] » December 25th 2019, 9:36am
by chevymaher » December 25th 2019, 11:57am
by xit » December 25th 2019, 4:34pm
by 90safari » December 26th 2019, 1:28am
by Brewtus [OP] » December 27th 2019, 7:11am
xit wrote:I have kept fuel records for many years on my astro, if I see a major drop in mileage, I know something needs attention If I average all the data over the years it would be right at 18mpg, highway and city. The milage is not too bad considering the age of the van & it is a box. Keeping my speed close to or lower than posted limit is the biggest factor in my mileage.
by Brewtus [OP] » December 27th 2019, 7:13am
90safari wrote:My 88 Astro gets 16-18 in the city, and 22 out on the highway. A lot of that is the rear gearing. I only say that, as my wife's 90 GMC Safari would get 14-15 around town, and 18 out on the highway.
by Mmusicman » December 27th 2019, 4:56pm
by M_a_t_t » December 27th 2019, 7:20pm
Brewtus wrote:Hello everyone!
I am interested in what you get for fuel economy with your van(s). I look forward to comparing numbers together and I hope this thread will serve as a resource to pool information and ideas together.
If you'd like to contribute, please list:
1.) Average Fuel Economy (MPG)
2.) Year, Model, & Engine Size
3.) Modifications Impacting Fuel Economy
4.) Other Relevant Ideas & Experiences Improving Fuel Economy
~Dylan
by Brewtus [OP] » December 27th 2019, 8:31pm
Mmusicman wrote:Don't be fooled! Changing your gearing either direction may move you out of the engine's "sweep spot".. the rpm range where it runs most efficiently AND effectively. Lower RPM (too low under the same load) often means MORE throttle (to maintain speed).. since it takes the same amount of HP to move you down the road regardless of rpm. I know.. been there done that. Often times heavier vehicles (with increased loads) may actually improve mileage with more/correct gear (up to a certain speed). It really depends on how hard you have to ride the throttle to maintain your desired speed. Slowing down (from higher highway speeds) usually will affect mileage.. mostly due to decreased wind load and tire resistance. I can get 18mpg (at slower speeds than I am uncomfortable with). Above 70 the mileage starts taking a harder dive (also depending on wind direction).. I've charted it all. I prefer however, to move with the flow and get there. I improved the mileage in my 92 by replacing the weak and worn V6 with a fresh V8 more suited to moving a van. There is NO one answer fits all
by Brewtus [OP] » December 27th 2019, 8:37pm
1. ~18
2. 95 2wd 4.3
3. E-fan, smooth wheel covers, MPGuino (not sure on tbi, but spider injection needs adapter module to use)
4. Biggest thing you can do is adjust how you drive and get some instrumentation. Aerodynamics is the killer for you. Check out ecomodder.com if you want some ideas.
It might sound farfetched, but my best trip (single drive not a tank) was 24 mpg. That was a very rare occurance though. No traffic and I hit all green lights. This required coasting and timing the lights to get. Engine was already warm as well.
I have since put a v8 in my van. Now I have adopted the "smiles per gallon" montra
x2 that nothing applies the same to each vehicle.
by M_a_t_t » December 29th 2019, 5:41pm
Brewtus wrote:I dig the mods you've done! How long ago did you find your MPGuino and do you know of anyone still selling them? What type or style of e-fan do you have? Adjustment of driving style is definitely an important aspect, especially with Brewtus haha. I am hoping to get either an MPGuino or SuperMID but have been unable to find a seller yet. I am a fan of ecomodder.com and will definitely be referring to the info on their site throughout the build. 24 MPG sounds great! Lights are such a killer of fuel economy... Your "smiles per gallon" montra is funny haha.
by AstroWill » December 29th 2019, 6:41pm
Brewtus wrote:"smiles per gallon"
by Brewtus [OP] » December 29th 2019, 10:37pm
M_a_t_t wrote:I bought it back around 2016. I bought mine through this seller, ( http://mpguino.wiseman.ee/eng ) but it looks like he has closed up shop. There is a schematic for building one on the mpguino wiki page ( https://ecomodder.com/wiki/MPGuino ) if you can follow it. The code is available (should be) for download so you just have to wire it up. If not I have an older version of the code on a google doc you can copy and paste in. I bought the red fans that everyone on here doesn't like. I can't say I would recommend them either, as I don't think mine have been working. I haven't looked into it yet to figure out if there was an installation issue or poor quality.
by AstroWill » December 30th 2019, 12:27am
by Brewtus [OP] » December 30th 2019, 7:09pm
AstroWill wrote:I saved some of what I could find https://sites.google.com/site/astrosafa ... ne/mpguino
by 90safari » January 9th 2020, 10:53pm
Brewtus wrote:90safari wrote:My 88 Astro gets 16-18 in the city, and 22 out on the highway. A lot of that is the rear gearing. I only say that, as my wife's 90 GMC Safari would get 14-15 around town, and 18 out on the highway.
Thank you for sharing! Do you know the difference in rear gearing between the two vans? I have read the longer the gears, the less power and higher mpg. I am interested in figuring out my gearing ratio.
by jeff1 » January 20th 2020, 1:21am
by MechBob » January 20th 2020, 1:41am
It is currently March 4th 2021, 10:32am
Uncategorized Forum |
Moderators: Leeann_93, icebrrg3rd |
Previous topic Next topic |
Sponsors |
