Need a measurement
Need a measurement
Postby Mr_Roboto [OP] » March 26th 2020, 2:17am
Can someone out there with a RWD get me the distance between the top of the tail shaft where the output seal is to the floor pan of the van? I'm trying to see if I need to make a spacer for my trans crossmember. I think that everything is hanging slightly low right now and could really use throwing an inch under it to get some more exhaust clearance.
Mr_Roboto
Firing on 1 Cylinder (L2)
Years of Membership: Mr_Roboto has been a member for 13 full yearsMr_Roboto has been a member for 13 full yearsMr_Roboto has been a member for 13 full yearsMr_Roboto has been a member for 13 full yearsMr_Roboto has been a member for 13 full yearsMr_Roboto has been a member for 13 full yearsMr_Roboto has been a member for 13 full yearsMr_Roboto has been a member for 13 full yearsMr_Roboto has been a member for 13 full yearsMr_Roboto has been a member for 13 full yearsMr_Roboto has been a member for 13 full yearsMr_Roboto has been a member for 13 full yearsMr_Roboto has been a member for 13 full years
Topics: 51
  • Need help with bodymount replacements
    by hippovan » September 10th 2020, 11:28pm in Exterior
    Last post by hippovan View the latest post
  • Need some advice
    by TheUnicorn » September 14th 2020, 8:34pm in Uncategorized
    Last post by N6KB View the latest post
    October 6th 2020, 9:31pm
    March 3rd 2021, 4:11am
Re: Need a measurement
Postby 81SAFARIMATT » March 26th 2020, 3:20pm
ok tranny comes back.... then a round piece at end of tranny then the u joint on drive shaft ...then the drive shaft for a few inches is thinner then it gets fatter the rest of the way back.... that is what i am looking at
i measured just behind the u joint on the thinner part of the drive shaft and from top of driveshaft to floor pan was 7 1/4 inches
1998 Safari RWD
hope that helps
98 safari...3 seats...4.3 v6....RWD...130,000 miles new .... LOVIN LIFE IN THE COLORADO MOUNTAINS
No good story ever started with a salad
81SAFARIMATT
Images: 2
Extra Info: RWD-4.3-
Postby Mr_Roboto [OP] » March 26th 2020, 3:55pm
Thanks for the info. Here's a pic of what I have. Need to measure but I'm betting I'm about 2" low
Mr_Roboto
Topics: 51
Postby 81SAFARIMATT » March 26th 2020, 4:30pm
6 inches ....maybe a hair over ....Matt
81SAFARIMATT
Images: 2
Postby Mmusicman » March 26th 2020, 6:09pm
I find this discussion interesting in the fact I was just looking at my stock drive-line on my 92 (last night)... and for the first time I think my trans might be sitting a tad low. I haven't actually looked at it carefully enough, but it is sitting in stock mounts in stock location. There are proper trans > drive-shaft > pinion angles... which would concern me most. I need to take some actual measurements.
Ideally, the trans angle should be complimentary to the pinion... same as pinion angle.
I had to space my NP233 transfer case up quite a bit to get better output angle.. but I attribute this to the 233 being smaller than the stock AWD case... which caused it to sit lower.
Here is how I spaced mine (on my 2000)
A couple photo suggestions regarding angles:
pinion trans angle 01.jpeg (38.01 KiB) Viewed 423 times
It should probably be noted (in next photo) that "perfect inline" is not actually considered best.
Ideal is considered to be more like 1-3 degree matching angles (like 2nd illustration)..
SIDENOTE: If you have a level edge on you phone (remove from case)... I found it to offer quite accurate results with a good app. Surprisingly, it can give you measurements in the decimal 1/10th's of a degree angles (or even 1/1000th's with utility app)... far more accurate than my actual angle too. :D
Here are two screen shots (from my phone)
1) is a simple "bubble" app (I use this often)
2) is more complex utility app (reads actual sensor data)
Topics: 73
Images: 49
Postby AstroWill » March 26th 2020, 6:27pm
81SAFARIMATT wrote:6 inches ....maybe a hair over ....Matt
That's probably the average.
Images: 472
Postby Mr_Roboto [OP] » March 26th 2020, 6:38pm
I have a mag angle gauge. I'll probably take some measurements today but looking at it as per the floor level I'm about 1.5" low. That's good because that should net me a lot of clearance on the exhaust that I don't have right now.
Mr_Roboto
Topics: 51
Return to Uncategorized
It is currently March 3rd 2021, 4:11am
Uncategorized Forum
Attached by: icebrrg3rd
icebrrg3rd
in Uncategorized
Comments: 2995
Date: Feb 23 '21
Time: 6:27pm
in Uncategorized
Comments: 16420
Date: Feb 16 '21
Time: 8:08pm
Coronavan
in Uncategorized
Comments: 235
Date: Feb 14 '21
Time: 4:06am
Upstatevanvibes
in Uncategorized
Date: Feb 14 '21
Time: 3:20am
Coronavan
in Uncategorized
Date: Feb 14 '21
Time: 1:18am
