Seafoam
Seafoam
Postby snodog600 [OP] » February 25th 2012, 10:33pm
Feedback from anyone that has used Seafoam treatment..... Does this stuff work?
snodog600
Years of Membership: snodog600 has been a member for 9 full yearssnodog600 has been a member for 9 full yearssnodog600 has been a member for 9 full yearssnodog600 has been a member for 9 full yearssnodog600 has been a member for 9 full yearssnodog600 has been a member for 9 full yearssnodog600 has been a member for 9 full yearssnodog600 has been a member for 9 full yearssnodog600 has been a member for 9 full years
Alias (AKA): Don
Extra Info: 4.3
Re: Seafoam
Postby RECox286 » February 25th 2012, 10:47pm
How do you intend to use it ? Be careful, knowing that it is an industrial strength solvent. Most of us use it as a fuel tank additive to keep
our systems clean. There are different thoughts about other uses, some swear by it, others swear at it. If you are careful, it is useful as
an oil system cleaner, but don't leave it in the engine for very long. I'm sure you will get other hits if you wait around long enough.
Uncle Bob
RECox286
Purple Status (L6)
Purple Status (L6)
Topics: 40
Alias (AKA): Uncle Bob
Extra Info: RWD V6 [325K mi]
Re: Seafoam
Postby snodog600 [OP] » February 25th 2012, 10:56pm
My intentions are for a fuel tank additive...I would like to keep the injection system clean and haven't been sold on some of the conventional fuel injection cleaners. Thanks for your input Uncle Bob!!
snodog600
Alias (AKA): Don
Extra Info: 4.3
Re: Seafoam
Postby RECox286 » February 25th 2012, 11:27pm
I prefer to use Lucas Fuel Injector Cleaner in my fuel tank. Actually, most of the injector cleaners will do the job, because they
are basically the same stuff. I think that the pricing has more to do with preferences than the ingredients. Most people reason
that if it costs more, it is better. Not always the case. Sometimes price is indicatve, but name and reputation wins in this case.
Uncle Bob
RECox286
Purple Status (L6)
Purple Status (L6)
Topics: 40
Re: Seafoam
Postby snodog600 [OP] » February 25th 2012, 11:34pm
Well I will give it a try...Thanks again!!
snodog600
Alias (AKA): Don
Extra Info: 4.3
Re: Seafoam
Postby Jasen » February 25th 2012, 11:44pm
If you search seafoam make your self a ham sandwich, there's pages and pages of reading on it here.
I'm a Journeyman woodworker,
Every projects a journey man.
200k
Ultra gauge
Topics: 260
Images: 101
Re: Seafoam
Postby snodog600 [OP] » February 25th 2012, 11:54pm
Just ordered wings....should be better than ham!!
snodog600
Alias (AKA): Don
Extra Info: 4.3
Re: Seafoam
Postby Lumpy » February 26th 2012, 12:09am
I use SeaFoam as a gas tank additive once a year, with oil change. I also use it as a general fuel system cleaner in aerosol form to clean the throttle body, EGR, everything around the intake. Unrelated to cars I use it as a lubricant on outside metal things like gate hinges. It's not terribly caustic or acidic like Gumout or other carb cleaners. LIght oil, little bit of alcohol etc. Doesn't seem to bother rubber, plastic, paint, wire insulation etc. I spray a bit of it anywhere I want a little lube/protection. Battery terminals, distributor cap, hood latch, E brake cable, hose clamps.
I think the major difference in SeaFoam and most other fuel system cleaners is it's got "pale oil" in it. Lubricates the butterfly valves and so forth in the throttle body. I've done the big treatment where you put a pint through the vacuum boost intake. Seemed to clean the heck out of the intake system. Made things run smoother, idle a bit higher. I've also added it to the oil before changing. Not sure how to tell what kind of difference that might make. But it didn't make my engine fall out or my gaskets disintegrate, as some will have you think.
No magic. Just a clean and lubricated engine.
Re: Seafoam
Postby snodog600 [OP] » February 26th 2012, 12:08pm
Thanks for the input.. I think I may need to try it out! I have 200k on it and after a complete tune up its a little sluggish...so maybe a complete cleansing is in order!!
snodog600
Alias (AKA): Don
Extra Info: 4.3
Re: Seafoam
Postby tedanderson » February 27th 2012, 8:19pm
The only way that I've seen the effective use of it is when you suck it in to the engine through a vacuum line (as Lumpy stated)
I've done it on all of my vehicles at least once and I must say YES it really works!
What you would want to do is get the engine up to operating temperature, suck in about a third of the can while it's running, and then immediately shut the engine off and let it sit for about 15 minutes. Start it back up and then drive it until the smoke stops.
:driving:
Depending on how dirty your intake system is, you might want to do this after dark. ;)
tedanderson
Firing on 8 Cylinders (L3)
Topics: 76
Alias (AKA): 2Big4aMiniVan
Re: Seafoam
Postby snodog600 [OP] » February 28th 2012, 12:52am
Thanks for the opinion Ted...much appreciated!!
snodog600
Alias (AKA): Don
Extra Info: 4.3
Re: Seafoam
Postby Big_kid » February 28th 2012, 3:53am
Would you recommend a highway cruise afterward to make sure all the 'gunk' makes it all the way through?
Firing on 7 Cylinders (L7)
Topics: 185
Images: 342
Extra Info: 2WD 5.7 V8
Re: Seafoam
Postby Lumpy » February 28th 2012, 9:04pm
You'll see a lot of white smoke out of your exhaust while the oil in the SeaFoam, and other gunk, is burning. I think that's why Ted suggested night time. One way or another, I'd try and do a drive (or sit and run) that gets the revs up and heats the engine up. Gun it a few times to get the pressure of the engine to blow it all out the exhaust. You'll know you're done when the exhaust returns to normal.
Re: Seafoam
Postby Jasen » February 28th 2012, 11:28pm
Theres a video on here somewhere of an A/S member doing a Seafoam treatment but I can't find it.
Here's one off of youtube, it gets good 2 mins in.
200k
Ultra gauge
Topics: 260
Images: 101
Re: Seafoam
Postby snodog600 [OP] » February 28th 2012, 11:46pm
Speechless.... :rofl: :rofl:
snodog600
Alias (AKA): Don
Extra Info: 4.3
Return to Uncategorized
It is currently February 25th 2021, 8:48pm
Uncategorized Forum
Attached by: icebrrg3rd
icebrrg3rd
in Uncategorized
Comments: 2995
Date: Feb 23 '21
Time: 6:27pm
MmusicmanMmusicman is online!
in Uncategorized
Comments: 16418
Date: Feb 16 '21
Time: 8:08pm
Coronavan
in Uncategorized
Comments: 235
Date: Feb 14 '21
Time: 4:06am
Upstatevanvibes
in Uncategorized
Date: Feb 14 '21
Time: 3:20am
Coronavan
in Uncategorized
Date: Feb 14 '21
Time: 1:18am
Users browsing this forum: Majestic-12 [Bot] and 8 guests
