Rear heat lines from radiator
Postby AstroOafAdventurer [OP] » June 10th 2021, 10:43pm
My conversion van has lines tapped into the radiator that ran to the rear heat unit. I removed said unit and wish to remove the lines. When I removed the unit I just looped the circuit, but I can see they are hard lines coming from the radiator, it seems other vans have these as well after a trip to the JY.
For simplicity sake, any harm in removing the lines from the radiator and replacing them with plugs?
I'm about to do a cooling system flush and would like to do this at the same time.
Anyone know what size plug I'd need for them?
97 Astrofari Conversion Van 62k 64k miles, 65k miles
AstroOafAdventurer
Topics: 50
Alias (AKA): Thorsteenster
Extra Info: RWD GMC grille
Re: Rear heat lines from radiator
Postby MI_Ghost » June 11th 2021, 9:51am
Hard lines from the radiator are usually oil cooler on left side. Transmission cooler on right side. Rear aux heater is normally taken off the heater control valve below the alternator on the subframe.
Do you have a pic of these lines?
~Ghost
Ast' Cargo: 2001 Astro Cargo
Beauty: 2009 Impala LT
https://www.astrosafari.com/gallery/sea ... r_id=66010
MI_Ghost
Firing on 4 Cylinders (L2)
Topics: 9
Images: 124
Alias (AKA): Ghost
Van Model Year: 2001
Extra Info: Big White RWD Box
Postby AstroOafAdventurer [OP] » June 11th 2021, 4:31pm
MI_Ghost wrote:Hard lines from the radiator are usually oil cooler on left side. Transmission cooler on right side. Rear aux heater is normally taken off the heater control valve below the alternator on the subframe.
Sorry, no pic but they are on the passenger backside of the radiator. You make sense, I have no idea why I thought those were coolant lines lol. Evidently I didn't trace the lines very well from the rear!
I do want to remove the oil cooler at next oil change and trans lines at next fluid change.
Thanks for that, I'll check out the heater control valve.
I'll have to check my door codes, looking in the rear heat/AC unit install it looks like vans with YF7 package had the lines in place under the van but capped off.
AstroOafAdventurer
Topics: 50
Postby Birdshake » June 11th 2021, 4:52pm
I wouldn’t recommend removing the trans cooler lines. If anything add an additional cooler inline with the radiator.
2005 4WD Astro Cargo
NP236 3.73 Eaton Posi
S10 HD Springs 3" blocks
245/75/16 BFG KO2
KYB Monomax
Birdshake
Years of Membership: Birdshake has been a member for 9 full yearsBirdshake has been a member for 9 full yearsBirdshake has been a member for 9 full yearsBirdshake has been a member for 9 full yearsBirdshake has been a member for 9 full yearsBirdshake has been a member for 9 full yearsBirdshake has been a member for 9 full yearsBirdshake has been a member for 9 full yearsBirdshake has been a member for 9 full years
Images: 30
Extra Info: 4.3 4WD
Postby MI_Ghost » June 11th 2021, 10:28pm
Birdshake wrote:I wouldn’t recommend removing the trans cooler lines. If anything add an additional cooler inline with the radiator.
^^I second this ^^
~Ghost
MI_Ghost
Topics: 9
Images: 124
Alias (AKA): Ghost
Postby AstroOafAdventurer [OP] » June 11th 2021, 10:48pm
There's a leak, or evidence of a previous leak, in one of the lines.
When I bought it I took it in for a pre-purchase inspection and was told trans lines were leaking but suspect it may have been the oil cooler lines.
I've yet to see nary a drop under it but the area definitely shows signs of a leak, oily road grime caked on/build up.
Next oil change I wanted to remove the oil cooler, clean the area up and monitor for fluid leaks and replace trans lines if needed, or maybe an aftermarket cooler.
AstroOafAdventurer
Topics: 50
Return to Uncategorized
It is currently June 25th 2021, 10:37am
Uncategorized Forum
Attached by: MHM
MHM
in Uncategorized
Time: 7:51pm
in Uncategorized
Comments: 9
Date: Jun 19 '21
Time: 5:35pm
Sailing_Faith
in Uncategorized
Date: Jun 17 '21
Time: 4:58am
Attached by: 97cargocrawler
97cargocrawler
in Uncategorized
Comments: 3082
Date: Jun 16 '21
Time: 8:43pm
elusivepastry
in Uncategorized
Comments: 16561
Date: Jun 16 '21
Time: 6:55am
Users browsing this forum: Google [Bot] and 18 guests
