by TaxiVan [OP] » September 23rd 2012, 7:56pm
by DRZ » September 23rd 2012, 8:01pm
by TaxiVan [OP] » September 23rd 2012, 8:07pm
DRZ wrote:Dreaming is fun but to start, your Astro has leaf rear springs and would be hard to change unless the fuel tank goes somewhere else imo.
by Jasen » September 23rd 2012, 8:43pm
by TaxiVan [OP] » September 23rd 2012, 9:01pm
Jasen wrote:I don't think you can use a FWD transaxle. Been some time sense I worked on a Toronado but as I recall it has a big bell housing just like a regular tranny, maybe bigger and the thing in itself is pretty huge, seeing you've got a whole tranny configured sideway's. Don't think you have the vertical clearance for it back there in regards to suspension travel. GM did do RWD transaxles, 61-63 in Pont. Tempest's and Old's Cutlass F 85 and of course the Corvair. The Pont. and Old's ran a torque tube drive shaft, which would be to short for the van if you could find the set up for a reasonable price. The problem with the Corvair is it was basically a reversed tranny seeing the motor was behind it.
Then you have to figure in building some hard points closer to the center line to mount a trans axle to as well as the rear suspension.
by Jasen » September 23rd 2012, 10:46pm
by TaxiVan [OP] » September 23rd 2012, 10:58pm
Jasen wrote:Don't know why it didn't come to mind before, Corvette and Jaguar.
by Shad0wXCalibur » September 24th 2012, 12:35pm
by Mr_Roboto » September 24th 2012, 7:03pm
by Jasen » September 24th 2012, 8:08pm
Shad0wXCalibur wrote:That reminds me of a Dodge Intrepid transmission. I walked past one in the junkyard once. The whole drivetrain is longitudinal like a truck except I thought they were FWD. Well it is. The CV axles came out the sides of the transmission like that picture. Had never seen that before. Of course a transmission in the REAR like on the corvette is like woah to me. Didn't know they were made like that. Kinda trippy looking.
by TaxiVan [OP] » September 25th 2012, 1:13am
Mr_Roboto wrote:The C5 axle is a 4L60E, or a T56. Later stuff has a 6L80E or 6l80E I think. Don't quote me on the 6 spd autos however.
by tedanderson » September 25th 2012, 1:38am
Jasen wrote: GM did do RWD transaxles, 61-63 in Pont. Tempest's and Old's Cutlass F 85 and of course the Corvair.
by Jasen » September 25th 2012, 1:50am
by Lumpy » September 25th 2012, 2:24am
Jasen wrote:
Oh yea, the Firero...
by TaxiVan [OP] » September 25th 2012, 6:02am
tedanderson wrote:Jasen wrote: GM did do RWD transaxles, 61-63 in Pont. Tempest's and Old's Cutlass F 85 and of course the Corvair.
Don't forget the Fiero. Well.. OK. So technically it was MID engine but for all purposes of discussion here, it was indeed a rear transaxle setup.
Jasen wrote:Oh yea, the Firero. Talk about the best place to put a distributor
by cowboydan » September 26th 2012, 4:49pm
by TaxiVan [OP] » September 26th 2012, 11:16pm
cowboydan wrote:taxivan, it is possible to swap in part time 4x4 from awd, rather simple. t-case, front drive shaft, front diff axle tube (long side), wiring for the selector on the dash. as far as some pics of the corvette rear end, you have 2 issues, torque tube and housing the transmission in the rear. converting a van would be right up there with the best of ideas. there will be alot of gemoetry and physics to think about
by cowboydan » September 27th 2012, 5:11am
by TaxiVan [OP] » September 27th 2012, 11:11am
by MadMaxiVan » September 27th 2012, 1:36pm
It is currently February 26th 2021, 4:57pm
Uncategorized Forum |
Moderators: Leeann_93, icebrrg3rd |
Previous topic Next topic |
Sponsors |
