Cardboard hood insulator
Postby chrisgerman1983 [OP] » December 18th 2012, 4:09pm
I made a hood insulator out of two layers of cardboard. I used high heat contact adhesive and sealed the cardboard with wipe on poly. I don't have any numbers yet to prove the decreased warmup time but my windows now defrost before the hood and I have usable heat from the heater core much faster then before. I will take some temp measurements with and without the insulator. It helps my intake temp as well. Well worth the ten minutes it took :mrgreen:
chrisgerman1983
Fueling (5/8 tank)
Fueling (5/8 tank)
Years of Membership: chrisgerman1983 has been a member for 8 full yearschrisgerman1983 has been a member for 8 full yearschrisgerman1983 has been a member for 8 full yearschrisgerman1983 has been a member for 8 full yearschrisgerman1983 has been a member for 8 full yearschrisgerman1983 has been a member for 8 full yearschrisgerman1983 has been a member for 8 full yearschrisgerman1983 has been a member for 8 full years
Van Model Year: 1996
  • Ignition switched power source under hood
    by snailsafari » September 4th 2020, 10:45pm in Electrical
    Last post by Sailing_Faith View the latest post
    September 6th 2020, 6:12pm
  • Hood lifts
    by Toskavat » November 16th 2020, 1:58am in Uncategorized
    November 17th 2020, 4:44am
    9
    92
    January 26th 2021, 10:40pm
Re: Cardboard hood insulator
Postby DRZ » December 18th 2012, 4:51pm
I unhook the snout from the air cleaner assy that is designed for getting the engine cooler air in the summer and also picks up water in the spring high water periods. Put it back on for summer so it can do its cool air thing. The cardboard thing never occurred to me before. My LT astro-mino has a felt type pad under the hood stock.
DRZ
Firing on 5 Cylinders (L2)
Years of Membership: DRZ has been a member for 12 full yearsDRZ has been a member for 12 full yearsDRZ has been a member for 12 full yearsDRZ has been a member for 12 full yearsDRZ has been a member for 12 full yearsDRZ has been a member for 12 full yearsDRZ has been a member for 12 full yearsDRZ has been a member for 12 full yearsDRZ has been a member for 12 full yearsDRZ has been a member for 12 full yearsDRZ has been a member for 12 full yearsDRZ has been a member for 12 full years
Topics: 53
Images: 55
Alias (AKA): HPbyStan
Extra Info: awd cargo Alloys
Postby chrisgerman1983 [OP] » December 18th 2012, 8:24pm
Mine also has the felt but the extra insulation helps. I also run a warm air intake in the winter. I ran some flexible aluminum ducting down to the exhaust manifold. My intake temp is usually around 50 degrees once I'm warmed up. It goes into closed loop almost right away. I used to be in open loop untill I was almost at work.
chrisgerman1983
Fueling (5/8 tank)
Fueling (5/8 tank)
Postby smokinjoe » December 20th 2012, 5:11am
Isnt cardboard kina flammable? Just seems like it may be a concern.
smokinjoe
Topics: 268
Alias (AKA): smokinjoe
Van Model Year: 2002
Extra Info: RWD
Postby chrisgerman1983 [OP] » December 20th 2012, 3:12pm
It was a slight concern at first, until I read that the ignition point of cardboard is 800f. much higher then the plastic and rubber that is under our hoods. It would take direct flame to ignite. Most people have paper air filters and the intake is the only place I have ever seen flame come from an engine... other then the exhaust at the races.
chrisgerman1983
Fueling (5/8 tank)
Fueling (5/8 tank)
Postby chrisgerman1983 [OP] » December 20th 2012, 3:29pm
I have the numbers with and without the cardboard :blah: this is with a grill block and partial belly pan. The hood insulator on its own would not likely have any benefit. Not sure if anybody cares but ill post em up anyway.
All times were within 20 minutes of the temps beside each other
The warmup time for the coolant was not affected but intake temps were higher with the cardboard, the cool down time was significantly different. for anybody who drives through out the day it would make the difference between having heat and closed loop immediately or waiting a couple minutes. For anybody who doesn't know the importance of open/closed loop, My fuel economy doubles as soon as it goes closed loop :mrgreen:
with C/B ----- Without C/B
Engine on ----- Engine on
07:55 - 41f ----- 41f
07:57 - 59f
07:59 - 106f
08:01 - 129f
08:02 - 145f
08:03 - 161f
08:05 - 187f ----- 187f
Engine off ----- Engine off
08:17 - 167f
08:31 - 156f ----- 146f
08:48 - 144f
09:12 - 129f ----- 108f
09:43 - 122f ----- 97f
10:19 - 122f ----- 71f
12:12 - 75f ------ 61f
chrisgerman1983
Fueling (5/8 tank)
Fueling (5/8 tank)
Return to Uncategorized
It is currently January 26th 2021, 10:40pm
Uncategorized Forum
Attached by: mglsite
mglsite
in Uncategorized
Comments: 16388
Date: Jan 24 '21
Time: 10:12pm
in Uncategorized
Comments: 17
Date: Jan 22 '21
Time: 12:56am
in Uncategorized
Comments: 17
Date: Jan 21 '21
Time: 10:23pm
Rockridge
in Uncategorized
Comments: 2980
Date: Jan 19 '21
Time: 12:03am
Ram
in Uncategorized
Comments: 17
Date: Jan 17 '21
Time: 6:51pm
