by romeroom [OP] » April 15th 2009, 2:16am
by Matrixx » April 15th 2009, 3:22am
by astro355 » April 15th 2009, 3:44am
Matrixx wrote:HI romeroom
Would it be possible to get a picture of the broken bolt? Thanks.
by romeroom [OP] » April 15th 2009, 3:54am
by astro355 » April 15th 2009, 4:01am
by romeroom [OP] » April 15th 2009, 5:39am
astro355 wrote:Actually, can you take a picture of the rest of the bolt in the frame?
by Matrixx » April 15th 2009, 2:01pm
by romeroom [OP] » April 15th 2009, 5:22pm
Matrixx wrote:Hi romeroom
If you could get a picture of it, that would be great. If it's a flush break, and their is no access to that broken bolt from the other side, then my suggestion here is to drill it and use an "Easy Out" on it. Start with a small drill bit first for a pilot hole, then work into a bigger one after that.
The hole drilled "must" be straight in relation to the bolt your removing. The final hole drilled must be at least half the thickness of the bolt or more to get any kind of leverage on it. Might I suggest you replace the other bolt as well holding that idler arm on and use a torque wrench to tighten them. 77ft/lbs. is the proper torque for them. Hope something here helps RR. Please keep us updated, thanks.
by Matrixx » April 15th 2009, 11:26pm
by romeroom [OP] » April 17th 2009, 2:34am
by romeroom [OP] » April 17th 2009, 3:44am
by romeroom [OP] » April 17th 2009, 11:35am
romeroom wrote:... Does anyone know what size drill bit I need to make the needed hole? Thanks.
by Matrixx » April 18th 2009, 5:46am
by Big_kid » April 18th 2009, 1:47pm
by romeroom [OP] » April 18th 2009, 10:27pm
It is currently February 26th 2021, 11:11am
Uncategorized Forum |
Moderators: Leeann_93, icebrrg3rd |
Previous topic Next topic |
Sponsors |
