Headlights Stuck on High Beams!
Postby Datamater [OP] » February 25th 2008, 7:17pm
Greetings -
Long time lurker, 1st time poster here. As the subject line says, my headlights are stuck in the high-beams mode, which is keeping me from inspecting my tired Astro ('89 "shorty" 4.3 w/ 188K miles) and causing much ill will from oncoming drivers. The bulbs are OK (the low-beam filaments are good), as is the 30-amp fuse marked "horn/dmr". The lights dim somewhat when I tug on the multifunction lever, which tells me the problem is somewhere in the switch itself. Problem is, I don't know how to access the switch! I presume it's in the column somewhere.
I tried a search here to no avail, and my Haynes book offers no guidance. Is this a common problem? Will I have to pull the steering wheel, or is there an easier way to access this switch? is this a common GM part? Please advise. Thanks in advance!
- Russ
Datamater
Years of Membership: Datamater has been a member for 12 full yearsDatamater has been a member for 12 full yearsDatamater has been a member for 12 full yearsDatamater has been a member for 12 full yearsDatamater has been a member for 12 full yearsDatamater has been a member for 12 full yearsDatamater has been a member for 12 full yearsDatamater has been a member for 12 full yearsDatamater has been a member for 12 full yearsDatamater has been a member for 12 full yearsDatamater has been a member for 12 full yearsDatamater has been a member for 12 full years
  • no low beams
    by Dorwink » October 24th 2020, 1:38am in Electrical
    October 28th 2020, 11:50pm
  • Lost Reverse & 2nd Gear, Ecode752=Shift Solenoid A stuck on
    by RandyHip » September 21st 2020, 9:03pm in Automatic
    September 21st 2020, 10:26pm
    67
    December 2nd 2020, 1:23pm
Re: Headlights Stuck on High Beams!
Postby wmjwhite » February 27th 2008, 1:46am
Switch is at the bottom of the column and connects to the muliswitch lever via a long metal rod. You just need to pull the plastic cover off the bottom, disconnect the old switch wiring harness, unbolt it, fuss with the lock rod and replace. Twenty minutes laying on your back under the dash cursing at the world is all it takes.
'87 Astro CL RWD 4.3 w/ Automatic
wmjwhite
Years of Membership: wmjwhite has been a member for 12 full yearswmjwhite has been a member for 12 full yearswmjwhite has been a member for 12 full yearswmjwhite has been a member for 12 full yearswmjwhite has been a member for 12 full yearswmjwhite has been a member for 12 full yearswmjwhite has been a member for 12 full yearswmjwhite has been a member for 12 full yearswmjwhite has been a member for 12 full yearswmjwhite has been a member for 12 full yearswmjwhite has been a member for 12 full yearswmjwhite has been a member for 12 full years
Resolved: Headlights Not Stuck on High Beams!
Postby Datamater [OP] » February 28th 2008, 2:48am
That was it! Actually it took me closer to 45 minutes, but it would've been an hour if I hadn't used the profanity. Thanks!
- Russ
Datamater
Return to Uncategorized
It is currently December 2nd 2020, 1:23pm
Uncategorized Forum
foxfire
in Uncategorized
Comments: 16275
Date: Nov 30 '20
Time: 2:25am
Attached by: chevymaher
in Uncategorized
Date: Nov 28 '20
Time: 5:28pm
in Uncategorized
Date: Nov 28 '20
Time: 4:01pm
in Uncategorized
Comments: 16275
Date: Nov 27 '20
Time: 6:33pm
Attached by: icebrrg3rd
icebrrg3rd
in Uncategorized
Comments: 16275
Date: Nov 24 '20
Time: 5:55pm
