new owner - diagnosing front hub noise and a few other ??
Postby mattds [OP] » August 25th 2013, 5:15am
Hi there,
After about 5 years of admiring these vans, i finally took the plunge and replaced my 98 dodge ram van 3500 with a 2004 GMC cargo AWD! It's absolutely perfect for my occasional reno work, general hauling and camping.
I have a few questions, the previous owner told me that it will need new front hubs, but how can i be sure - the noise certainly sounds like the constant bearing type of noise (verses changing volume and pitch of bad tires). being new to these vans i can't tell i the ride is any different - would bad hubs actually affect the ride? Further if i do change them, is it worth it going for the Timken - this might see 5000k a year max. no off roading, just some over sized tires, and usually driven around with 200lbs of tools it the back (so pretty much empty).
another question - where can i find a maintenance schedule?
And i have the GMC cargo version, so the front end is an older style with square lights with built in bulbs...what are these called?
Thanks
m
mattds
Years of Membership: mattds has been a member for 7 full yearsmattds has been a member for 7 full yearsmattds has been a member for 7 full yearsmattds has been a member for 7 full yearsmattds has been a member for 7 full yearsmattds has been a member for 7 full yearsmattds has been a member for 7 full years
Topics: 12
Alias (AKA): Matthew
Extra Info: awd cargo 3.42 g80
  • New Front 2000 AWD Hub
    by Mmusicman » November 6th 2020, 7:15pm in Stock Suspension
    Last post by tungtide View the latest post
    November 6th 2020, 10:21pm
  • AC diagnosing help
    by AstroOafAdventurer » September 16th 2020, 3:50am in Climate Control
    Last post by AstroOafAdventurer View the latest post
    September 22nd 2020, 2:17am
    9
    53
    March 1st 2021, 8:58am
Re: new owner - diagnosing front hub noise and a few other ?
Postby Don1806 » August 25th 2013, 8:35am
Do a search here for the term "encoder motor" and look through those posts. The encoder motor facilitates the AWD and when that motor goes, the noise under the front increases dramatically. Easy fix if that's all it is. Others who are more technical can provide you with more direct questions to help diagnose further.
I would eliminate the encoder motor first before I started replacing hubs. My hubs have 160,000 plus miles on them with no problems. My encoder motor went at about 150,000.
99 Astro LT - Orginal Owner.
Don1806
Years of Membership: Don1806 has been a member for 10 full yearsDon1806 has been a member for 10 full yearsDon1806 has been a member for 10 full yearsDon1806 has been a member for 10 full yearsDon1806 has been a member for 10 full yearsDon1806 has been a member for 10 full yearsDon1806 has been a member for 10 full yearsDon1806 has been a member for 10 full yearsDon1806 has been a member for 10 full yearsDon1806 has been a member for 10 full years
Topics: 18
Images: 2
Alias (AKA): Don
Extra Info: AWD 170K
Postby Drummernaut » August 25th 2013, 5:34pm
Lift the front end and shake the wheels. There should be little to no play. You will know.
If you want to take the listing to one side or the other when turning, I hear just the front set of Timkens can get the job done.
Maintenance schedule can be found in the owners manual 3/4 down on the front page of this site:
viewforum.php?f=122
1999 Astro LT AWD
MODS: Electric fan, Transmission cooler/fan, AWD engaged LED
Drummernaut
Years of Membership: Drummernaut has been a member for 10 full yearsDrummernaut has been a member for 10 full yearsDrummernaut has been a member for 10 full yearsDrummernaut has been a member for 10 full yearsDrummernaut has been a member for 10 full yearsDrummernaut has been a member for 10 full yearsDrummernaut has been a member for 10 full yearsDrummernaut has been a member for 10 full yearsDrummernaut has been a member for 10 full yearsDrummernaut has been a member for 10 full years
Topics: 9
Alias (AKA): Drummer From Hell
Extra Info: LT V6 AWD
Postby Leeann_93 » August 26th 2013, 12:27am
And yes, the Timkins are worth it.
Postby mattds [OP] » August 27th 2013, 9:20pm
Well i have changed all the fluids except the rear diff as the plug is cold welded (I tried everything I can think of - including wedling on a bolt to it) so it looks like i'll have to either tap the cover or crack open the cover and fill it through the vent...
my drive line binding has gone away, and the awd is working well. Also put on monroe (i know they are not the best, but it's what was easily avaialble) front shcoks and rear coilovers - they lifted the rear about half an inch so right now I am level with the front which has a 1.5" torsen twist.
I'd still like come guidance on how to confirm that noise that i hear is indeed the front bearings.
thanks
matt!
mattds
Topics: 12
Postby mattds [OP] » September 5th 2013, 4:59pm
for what it's worth, the grinding or roaring noise was indeed the front bearing and it went away. I also experinced what i thought was a rough ride after the shocks, but it turns out those were just a little loose after a few days of driving and needed to be tightned up.
Now i have to tackle a werid rubbing noise from the back after the brakes were done, an exhust leak and at some point some the rear axle and pinion bearings - anyone have a good 'how to' on that?
mattds
Topics: 12
Return to Uncategorized
It is currently March 1st 2021, 8:58am
Uncategorized Forum
Attached by: icebrrg3rd
icebrrg3rd
in Uncategorized
Comments: 2995
Date: Feb 23 '21
Time: 6:27pm
in Uncategorized
Comments: 16419
Date: Feb 16 '21
Time: 8:08pm
Coronavan
in Uncategorized
Comments: 235
Date: Feb 14 '21
Time: 4:06am
Upstatevanvibes
in Uncategorized
Date: Feb 14 '21
Time: 3:20am
Coronavan
in Uncategorized
Date: Feb 14 '21
Time: 1:18am
