my oil dipstick came out
Postby timshwah [OP] » September 14th 2013, 9:44pm
When I was changing my alternator on my 92 Astro EXT RWD 4.3L the oil dipstick tube came out. it popped out easily, I saw a post for a 2000 that said there's two halves to the tube I don't know if mine is the same. how do I get it back in where would I find the bottom half or if the whole thing came out where does it go. its the one that bolts to the alternator mount. :confused:
timshwah
Years of Membership: timshwah has been a member for 7 full yearstimshwah has been a member for 7 full yearstimshwah has been a member for 7 full yearstimshwah has been a member for 7 full yearstimshwah has been a member for 7 full yearstimshwah has been a member for 7 full yearstimshwah has been a member for 7 full years
Images: 4
Extra Info: 4.3L V6
  • Lost oil ptessure, oil all over motor
    by equitube » September 26th 2020, 1:51am in Engines
    September 26th 2020, 3:25am
  • Gauges activated with out keys in car
    by Wiiscow » August 31st 2020, 6:21am in Electrical
    Last post by Wiiscow View the latest post
    7
    90
    February 25th 2021, 5:01pm
Re: my oil dipstick came out
Postby chevymaher » September 14th 2013, 9:55pm
Best shot I got of where they join. Comes up right there between the block and exhaust manifold. The little tab is where the bottom half bolts to the block. It joins right above that.
Postby RECox286 » September 14th 2013, 10:47pm
When you hold the tube in its' rightful place, it should be evident as to where to slide the end of the tube
into the block. Usually I have had no trouble inserting the tube into its' hole, which is probably why
it came out fairly easy.
Good hunting
Uncle Bob
RECox286
Purple Status (L6)
Purple Status (L6)
Topics: 40
Alias (AKA): Uncle Bob
Extra Info: RWD V6 [325K mi]
Postby timshwah [OP] » September 15th 2013, 4:03pm
thanks guys got it back in then it popped out again when lining it up with the bolt. then got it back in again luckily the dipstick never came out of the tube so it was easy enough :banana:
timshwah
Images: 4
Extra Info: 4.3L V6
Return to Uncategorized
It is currently February 25th 2021, 5:01pm
Uncategorized Forum
Attached by: icebrrg3rd
icebrrg3rd
in Uncategorized
Comments: 2995
Date: Feb 23 '21
Time: 6:27pm
in Uncategorized
Comments: 16418
Date: Feb 16 '21
Time: 8:08pm
Coronavan
in Uncategorized
Comments: 235
Date: Feb 14 '21
Time: 4:06am
Upstatevanvibes
in Uncategorized
Date: Feb 14 '21
Time: 3:20am
Coronavan
in Uncategorized
Date: Feb 14 '21
Time: 1:18am
Users browsing this forum: WoodButcherWoodButcher is online! and 13 guests
