OK well in no particular order:
"Vauge Steering"
Spent some time with a mate checking it all out and we worked out what needed replacing so have just spent a shed load of money on:
New Inner & Outer Track rod ends (totally shot!)
Moog Idler Arms (both are worn and loose)
Plus other brake parts (Rear drums, Shoes & springs and front pads)
Hopefully means once it all fitted it be a bit better!
"Fluid Change Query"
Well its been several weeks and lots of mixed miles (normal town driving, cruising and towing) and it all seems good, nice and smooth changes, no hesitation and no slippage, will prob give it another change the end of this year just to keep ontop of it and try to prevent any further damage from happening.
"Driver Side Mirror"
Managed to find one that fitted over here so all good again now
"Engine Flat"
This was an interesting one - wayed up the options of breaking the cat up vs the cost of a new one and cos im so skint lately we decided to break the innnards of the cat up - that was a fun job - who the heck decided the CAT and "Y" pipe should be one bit AND have to come out BACKWARDS!!
When we broke he innards up - you couldn't see through it at all - was really chocked up.....
Have to say the van sounded sweeeeeeeeet running with just the "Y" pipe and cat on it (well come on we had to!) bit too noisy to use daily bt nice anyhow!
Got the cat punchyed through and back together - all wokring perfectly - the engine is back to full power, goes like a bullet now and as an added bonus it sounds a little bit better with no cat restricting it hehe - oh and uber bonues - not a single error code!!!!!!!!!!
So finally getting ontop of the problems with the van - the next few purchases are going to be
Rear Shocks
Wheel bearings
Ignition barrel
Anyone have recommendations, both good and bad for shocks please??
Cheers all
