gas tank help???
gas tank help???
Postby 1iwilly [OP] » July 26th 2009, 12:03am
hello to all
i have a 97 awd ls accourding to the owners manual i have a 25 gallon gas tank
so if i run the tank all the way down until it is sitting on the actual empty red line when i re fuel should it take real close to the 25 gallons today i have to just about force 20.00 gallons i'm thinking that my gauge is kind of off
if when i'm driving and it shows 1/2 tank when i shut the van off then back on it will read between 1 to 2 lines over a 1/2 tank.??
1iwilly
Fueling (3/4 tank)
Fueling (3/4 tank)
Years of Membership: 1iwilly has been a member for 11 full years1iwilly has been a member for 11 full years1iwilly has been a member for 11 full years1iwilly has been a member for 11 full years1iwilly has been a member for 11 full years1iwilly has been a member for 11 full years1iwilly has been a member for 11 full years1iwilly has been a member for 11 full years1iwilly has been a member for 11 full years1iwilly has been a member for 11 full years1iwilly has been a member for 11 full years
Topics: 30
Alias (AKA): 1IWILLY
Extra Info: AWD VORTEC 4.3
  • Van stalled when stopped at a light and smelled like gas
    by blendergasket » November 12th 2020, 3:18am in Engines
    Last post by Big_kid View the latest post
    November 22nd 2020, 1:41am
  • Little gas turning left and a pop
    by jmderyke » December 26th 2020, 6:41pm in Rear-End
    Last post by ptysiek View the latest post
    December 30th 2020, 11:06am
    March 1st 2021, 2:52pm
Re: gas tank help???
Postby ihatemybike » July 26th 2009, 2:57am
These vans are know to have the fuel gauge jump around a little bit. Just think of those last five gallons below E as fuel reserves.
Aaron
Prev Astros:99,97,00,94,87,86
ihatemybike
Firing on 6 Cylinders (L2)
Topics: 68
Postby astro355 » July 26th 2009, 4:52am
Wow, I didn't know the newer ones came with a 25 gallon tank. I have to take a look at that. My 20 gallon tank is annoying on long hauls.
And my gas gauge is empty at 1/4 tank, sometimes. I never let it go below half anymore. Someday I'll fix that, someday.
astro355
Firing on 4 Cylinders (L6)
Extra Info: 355 V8 700R4
Postby Matrixx » July 26th 2009, 6:27am
Hi 1iwilly
Actually your fuel tank is:
27 US Gallons
22.4 Imperial Gallons
or
102 liters
2 gallons are unusable fuel.
Running your tank that low, is very hard on the fuel pump.
It's usually the sending unit inside the tank that gets faulty and then gives the odd readings your seeing.
Sometimes a bad ground or power supply can give off the wall readings as well.
Just a couple of things to look at.:)
Matrixx
Postby 1iwilly [OP] » July 26th 2009, 2:48pm
thanks for all the replies
i think the tank was remove before as to one of the fuel lines look very new. i'll wait until it is very low then take tank down and check for ground
1iwilly
Fueling (3/4 tank)
Fueling (3/4 tank)
Topics: 30
Postby ihatemybike » July 27th 2009, 2:06am
Here's the tank sizes and which years had them. I unfortunately have three vans with 25 gallon tanks, after I was used to the 27s.
Tank Sizes
17 gallon 1985-1989
27 gallon 1985-1996 GM24
25 gallon 1997-1999 GM24B
27 gallon 2000
27 gallon 2001-2005
Aaron
ihatemybike
Topics: 68
Postby astro355 » July 27th 2009, 3:59am
That seems a little odd. My tank will hold 20 gallons, unless the pumps are lying to me. I'm not completely filling my tank everytime but I easy put in 18 to 19 gallons regularly.
astro355
Postby Matrixx » July 27th 2009, 4:02am
Maybe they changed in the middle of 1997 with the fuel tank capacities. Here is what it says in the 1997 Owners Manual:
1997 Astro-Safari Fuel Tank Capacity
1997 Astro-Safari Fuel Tank Capacity.jpg (8.85 KiB) Viewed 935 times
Matrixx
Postby 'cudapaul » July 27th 2009, 4:15am
Originally, Chevy had a 19 (standard) or 27 (option) gallon fuel tank.
I believe that either in the late 80's or the early 90's (89-91) they dropped the standard 19 gallon version and made the 27 gallon standard. For some reason, probably emission related, they started listing the fuel tank as 25 gallons for a few years, and then went back to showing it as 27 gals.
Trust me, it doesn't matter what year your M/L van is, the larger fuel tank was always 27 gallons. And then some.
I'm not proud of it (potential fuel pump damage form running dry) but one time I put in about 27.2 gallons!
You will find that when the pump shuts off, you can add at least another 3-4-5 gallons into the tank.
And you're not filling up the evap cannister!
'cudapaul
Years of Membership: 'cudapaul has been a member for 13 full years'cudapaul has been a member for 13 full years'cudapaul has been a member for 13 full years'cudapaul has been a member for 13 full years'cudapaul has been a member for 13 full years'cudapaul has been a member for 13 full years'cudapaul has been a member for 13 full years'cudapaul has been a member for 13 full years'cudapaul has been a member for 13 full years'cudapaul has been a member for 13 full years'cudapaul has been a member for 13 full years'cudapaul has been a member for 13 full years'cudapaul has been a member for 13 full years
Alias (AKA): 'cudapaul
Extra Info: LT AWD
Postby astro355 » July 27th 2009, 4:19am
That's very true. Those pump handles are very sensitive and will shut off quickly once any back pressure from the vapors are experienced.
astro355
Return to Uncategorized
It is currently March 1st 2021, 2:52pm
Uncategorized Forum
Attached by: icebrrg3rd
icebrrg3rd
in Uncategorized
Comments: 2995
Date: Feb 23 '21
Time: 6:27pm
in Uncategorized
Comments: 16419
Date: Feb 16 '21
Time: 8:08pm
Coronavan
in Uncategorized
Comments: 235
Date: Feb 14 '21
Time: 4:06am
Upstatevanvibes
in Uncategorized
Date: Feb 14 '21
Time: 3:20am
Coronavan
in Uncategorized
Date: Feb 14 '21
Time: 1:18am
