grill and headlight swap ?
Postby GotV8 [OP] » July 31st 2009, 3:20am
A buddy of mine has a 2003 Astro Cargo van with the standard headlights and grill. He is wanting to replace this with the composite headlight and grill setup because he was wanting to change the grill but could not find the style he liked as well as wanting a chrome grill. Can these front componites be interchanged? ?
I have a 89 safari we swapped the V6 out for a 350 bored 30 over 514 solid lift cam 4 barrel carb.The cooling system is still the stock radiator I replaced the cluched fan for a solid mount 18" flex which did require modification of the fan shround.
GotV8
Years of Membership: GotV8 has been a member for 11 full yearsGotV8 has been a member for 11 full yearsGotV8 has been a member for 11 full yearsGotV8 has been a member for 11 full yearsGotV8 has been a member for 11 full yearsGotV8 has been a member for 11 full yearsGotV8 has been a member for 11 full yearsGotV8 has been a member for 11 full yearsGotV8 has been a member for 11 full yearsGotV8 has been a member for 11 full yearsGotV8 has been a member for 11 full years
Re: grill and headlight swap ?
Postby Matrixx » July 31st 2009, 6:31am
Hi GotV8
Yes they can be with a little work. It's a straight forward swap overall, just have all the parts that you need first from a donor vehicle.:)
Matrixx
Postby meetthespeakers » July 31st 2009, 7:38pm
I was trying to find my thread about it. I swapped from a Astro grille to a Safari Grill, back to a Astro Composite Grille. All plug and play. Bolt up the same, headlights bolt in. I think there was a small wiring change, but it was a year ago... so I am a little foggy. Did the swap in less than 30 minutes. Easy peasy.
viewtopic.php?f=11&t=1348
1998 Astro, 1993 Astro, 1976 Austin Mini Clubman Estate, 1975 Trabant, 1961 Morris Minor
meetthespeakers
Years of Membership: meetthespeakers has been a member for 12 full yearsmeetthespeakers has been a member for 12 full yearsmeetthespeakers has been a member for 12 full yearsmeetthespeakers has been a member for 12 full yearsmeetthespeakers has been a member for 12 full yearsmeetthespeakers has been a member for 12 full yearsmeetthespeakers has been a member for 12 full yearsmeetthespeakers has been a member for 12 full yearsmeetthespeakers has been a member for 12 full yearsmeetthespeakers has been a member for 12 full yearsmeetthespeakers has been a member for 12 full yearsmeetthespeakers has been a member for 12 full years
Topics: 69
Extra Info: Bagged
Return to Uncategorized
It is currently December 4th 2020, 3:28am
Uncategorized Forum
Attached by: xit
xit
in Uncategorized
Comments: 16281
Time: 4:15pm
foxfire
in Uncategorized
Comments: 16281
Date: Nov 30 '20
Time: 2:25am
Attached by: chevymaher
in Uncategorized
Date: Nov 28 '20
Time: 5:28pm
in Uncategorized
Date: Nov 28 '20
Time: 4:01pm
in Uncategorized
Comments: 16281
Date: Nov 27 '20
Time: 6:33pm
