swap to carburetor
swap to carburetor
Postby Luis Cancel [OP] » February 25th 2014, 3:47am
Hello Guys
I believe the astro van is compatible with s10 that is true? it is true can i just swap everything to the astro van? a good friend give a astro 1996 2 wheel drive but I would like 4x4 carburetor thank you
Luis Cancel
Years of Membership: Luis Cancel has been a member for 6 full yearsLuis Cancel has been a member for 6 full yearsLuis Cancel has been a member for 6 full yearsLuis Cancel has been a member for 6 full yearsLuis Cancel has been a member for 6 full yearsLuis Cancel has been a member for 6 full years
Alias (AKA): luis
  • 2005 Chavy Astro AWD Cargo Van V-8 Engine swap
    by Porsche928gts » May 26th 2020, 11:55pm in V8 Swap
    Last post by Porsche928gts View the latest post
    May 27th 2020, 10:15pm
  • High Roof Swap???
    by Astrapevan » June 16th 2020, 5:07am in Exterior
    Last post by M_a_t_t View the latest post
    September 15th 2020, 1:59am
    7
    72
    October 26th 2020, 5:55pm
Re: swap to carburetor
Postby chevymaher » February 25th 2014, 3:54am
Yes they are compatible. Computer issues between the years are the issue. It is always a pain when there is a computer involved.
Postby Mr_Roboto » February 26th 2014, 8:29pm
You're swapping a carbureted S10 powertrain into your van? I wasn't aware they made a 4.3L carbed S10 just the 60 degree engines. Converting to 4WD is another beast entirely as well, I mean it's been done but it will take quite a bit of work. Usually people do solid axles with them.
If you have the engine/trans/etc and you're talking about converting your van to 4WD/carb, you'd want a return regulator with a carb FP, the entirety of the ignition system from the carbed vehicle (preferably non computer as most anything past 81 or so is) The exhaust manifolds from the van will probably work if they don't hit anything but I'd probably keep the others in case they don't fit. The Vortec manifolds will probably be less restrictive overall.
Lots of work, I know it's not a solid answer but at the same time it's a pretty open ended question in some ways. You'll have to do a lot of fabrication especially in the field of going from 2WD to 4WD. If I were to do it I"d get the Edelbrock intake, a carb, return regulator, vac/mech advance distributor, a 700R4/TH350/TH400 trans and 4WD transfer case then do a solid axle swap up front. I'm not tryign to make it sound easy, because it will be anything but quite frankly.
Mr_Roboto
Firing on 1 Cylinder (L2)
Years of Membership: Mr_Roboto has been a member for 12 full yearsMr_Roboto has been a member for 12 full yearsMr_Roboto has been a member for 12 full yearsMr_Roboto has been a member for 12 full yearsMr_Roboto has been a member for 12 full yearsMr_Roboto has been a member for 12 full yearsMr_Roboto has been a member for 12 full yearsMr_Roboto has been a member for 12 full yearsMr_Roboto has been a member for 12 full yearsMr_Roboto has been a member for 12 full yearsMr_Roboto has been a member for 12 full yearsMr_Roboto has been a member for 12 full years
Topics: 51
Return to Uncategorized
It is currently October 26th 2020, 5:55pm
Uncategorized Forum
in Uncategorized
Comments: 16186
Date: Today
Time: 4:38pm
in Uncategorized
Date: Today
Time: 2:13pm
joeg
in Uncategorized
Date: Oct 23 '20
Time: 10:10pm
joeg
in Uncategorized
Date: Oct 23 '20
Time: 10:08pm
Attached by: AlpineVan
AlpineVan
in Uncategorized
Date: Oct 23 '20
Time: 6:26pm
