need help i get 100km with 25 liters of gas
Postby summitawd [OP] » October 23rd 2009, 2:25am
i get 100km with 25liters of gas
can some people here tell me a few thing i like what part 2 change so i can save $$$$$$ some peop;e told me i should get 100km with 14 to 15 liters
i didnt do tune up yet but ill reather do all my repairs at one time so i have less down time it a work van
i get the same mpg as it load or not and i got new wheels
and when i floor it doesnt go it revs but goes really slow but when i give it half on the pedle it moves out good so new trany or rebuild
so tell me every thing u know
and the only mods i have done it lift the back end with larger leaf spring and 2 battery 2 power the stero and ac to dc converter
also any one here has put the front of there van on bags need some info and so i can have it level right now it like the old school car with the back end in the air and the front on the road
summitawd
Years of Membership: summitawd has been a member for 12 full yearssummitawd has been a member for 12 full yearssummitawd has been a member for 12 full yearssummitawd has been a member for 12 full yearssummitawd has been a member for 12 full yearssummitawd has been a member for 12 full yearssummitawd has been a member for 12 full yearssummitawd has been a member for 12 full yearssummitawd has been a member for 12 full yearssummitawd has been a member for 12 full yearssummitawd has been a member for 12 full yearssummitawd has been a member for 12 full years
Topics: 16
Alias (AKA): turboawdsummit 12 sec
  • Van stalled when stopped at a light and smelled like gas
    by blendergasket » November 12th 2020, 3:18am in Engines
    Last post by Big_kid View the latest post
    November 22nd 2020, 1:41am
  • Little gas turning left and a pop
    by jmderyke » December 26th 2020, 6:41pm in Rear-End
    Last post by ptysiek View the latest post
    December 30th 2020, 11:06am
    55
    April 17th 2021, 12:36pm
Re: need help i get 100km with 25 liters of gas
Postby astro355 » October 23rd 2009, 2:33am
Doing all of the repairs at the same time will make it hard to diagnose what the actual problem is. If you know it needs a tune-up, do that first and go from there.
astro355
Firing on 4 Cylinders (L6)
Extra Info: 355 V8 700R4
Postby ihatemybike » October 23rd 2009, 12:42pm
I used this tool to convert to MPG/US.
http://www.onlineconversion.com/fuel_consumption.htm
That is 9.4 MPG to us here in the states and not good at all. My 90 day average with Grumpy is almost double that.
A good tuneup might help and is never a bad idea, but your comment about flooring it vs half pedal does make it sound like you are losing power somewhere in the trans. Does the high rev / no go only happen from a stand still or does it happen when you floor it at speed too? When was the last time the trans had its fluids/filter done?
What conditions do you mostly drive in? Hills, traffic, hi-way, etc.
Please take the time to add your van's information to your profile/signature as this will help us in our diagnosis.
Aaron
Prev Astros:99,97,00,94,87,86
ihatemybike
Firing on 6 Cylinders (L2)
Topics: 68
Postby astro355 » October 23rd 2009, 12:51pm
ihatemybike,
a lot of times transmissions shift funny because of a problem starting with the engine. So if the engine is not putting out enough (expected) power, the transmission will act goofy also.
It makes it a lot easier to diagnose a problem when known faults are corrected.
astro355
Postby rev_les » October 23rd 2009, 1:15pm
:goodpost:
most people don't realize, a poorly tuned engine, esp on the older vacuum modulated setups, can kill an automatic transmission.
NRA Lifetime Member
2'nd amendment supporter
'13 Jeep Patriot
'87 Monte Carlo SS
'79 Avco 32' RV
rev_les
Firing on 2 Cylinders (L3)
Years of Membership: rev_les has been a member for 12 full yearsrev_les has been a member for 12 full yearsrev_les has been a member for 12 full yearsrev_les has been a member for 12 full yearsrev_les has been a member for 12 full yearsrev_les has been a member for 12 full yearsrev_les has been a member for 12 full yearsrev_les has been a member for 12 full yearsrev_les has been a member for 12 full yearsrev_les has been a member for 12 full yearsrev_les has been a member for 12 full yearsrev_les has been a member for 12 full years
Topics: 39
Alias (AKA): Les
Extra Info: LS 4.3 RWD
Postby summitawd [OP] » October 23rd 2009, 5:42pm
hey there thanks 4 the info so far
ill give u some more imput
i drive a mix city and highwaydriveing
it a 97 safari cargo but it fully load as i mean it got pw pl abs tow kit lsd rear end trans cooler larger leaf spring in the back and it purple to and it all from gmc too
i talk to the last guy that own it and he told me when he got it he maxed it out because it was a tax wright off 4 him
and yes it lsd in the back i know because when i do a brun out both wheel leve a mark
and so far as my trans proble i have think i found the proble it might be the cat so im going 2 put a test pipe in there and the other reasonis that on the highway i can drive 100 km or 65 miles and flooor it and ill will be doing 180km or 110 miles in a few sec and i dont what 2 go faster because the van starts shaking
summitawd
Topics: 16
Return to Uncategorized
It is currently April 17th 2021, 12:36pm
Uncategorized Forum
Attached by: icebrrg3rd
icebrrg3rd
in Uncategorized
Comments: 16497
Time: 12:50am
MmusicmanMmusicman is online!
in Uncategorized
Comments: 16497
Date: Apr 15 '21
Time: 10:41pm
Rockridge
in Uncategorized
Comments: 3035
Date: Apr 15 '21
Time: 4:33pm
Attached by: chevy57bert
chevy57bert
in Uncategorized
Comments: 3035
Date: Apr 13 '21
Time: 10:45pm
rozmpatterson
in Uncategorized
Comments: 3035
Date: Apr 13 '21
Time: 5:38pm
