96 Astro AWD Problems
Postby sxfx [OP] » December 2nd 2009, 6:11pm
Hey guys I'm in a dire need of help let me post my problem here from the beginning to now.
About 3 weeks ago i purchased a 1996 awd Astro van, with only 109k miles on it. The van is in awesome shape but I guess it stood around for a while and when I took it and started to drive it home about 200 miles away, the gasket on the rear diff pumpkin went.
I realized way too late and fried my diff. No problem I left my car 200 miles away from home at a local mechanic who replaced my rear diff.
I pick the car up couple days later, and find out that it developed a thump and jerking from the front diff all the way till about 35mph and then it would go away and the van drove beautifully.
So I took it home. Found a front diff from a all wheel drive 93 and swapped it into my 96. Changed the fluid in my transfer case to Dexron 6, changed the filter and fluid in my Trans, and put synthetic gear oil in the front diff.
So I proceed to drive the van and got really really excited no more jerking no more thumping the van drives beautifully.
But I got excited too soon. After about 15 minutes of driving when the van warmed up I started hearing a weird whining noise but couldn't quite possibly put my finger on where its coming from, it sounds like the rear but not sure, and as soon as the whining noise starts happening the van gets kinda wobbly especially when you get to speeds higher then 35mph, now the wobbly effect could also kind of be explain that the steering feels that each wheel is trying to go a different way.
So my question is what the heck before I replaced the front the diff the van ran fine except it had had the thunking and jerking in front until you got to 35mph, with a new front diff the jerking and thunking go away but the above mentioned problem evolves.
Only guess I have right now after doing some research is that the front diff I got from the 93 is a different gear ration then my rear one.
My rear gear ratio is 4:32 like the stock, and like a dumb *** I never checked what gear ratio that front is from the 93 astro i got.
What are the effects of running a differ gear ration in the front, how would the car behave?
Any help or suggestions are much appreciated.
P.S. I also posted this by accident in the automatic trans section of this forum.
sxfx
Years of Membership: sxfx has been a member for 12 full yearssxfx has been a member for 12 full yearssxfx has been a member for 12 full yearssxfx has been a member for 12 full yearssxfx has been a member for 12 full yearssxfx has been a member for 12 full yearssxfx has been a member for 12 full yearssxfx has been a member for 12 full yearssxfx has been a member for 12 full yearssxfx has been a member for 12 full yearssxfx has been a member for 12 full yearssxfx has been a member for 12 full years
  • 96 Astro in Seattle
    by rozmpatterson » October 26th 2020, 6:52pm in Projects/Builds
    October 31st 2020, 4:43pm
  • 1989 Astro Tiger power problems
    by astrotiger1989 » August 10th 2020, 7:31pm in Projects/Builds
    August 11th 2020, 9:45pm
    7
    94
    December 2nd 2020, 1:50pm
Re: 96 Astro AWD Problems
Postby sxfx [OP] » December 2nd 2009, 7:17pm
Upon further inspection, I have a feeling that the viscous coupling in my t-case has seized up is causing my problems. I think whats happening is since the viscous coupling sized up its transferring full power between the front and rear wheels none stop even on dry ground, causing my van to become unstable since all four wheels are trying to fight each other.
This would also make sense because these problems don't seem to occur until the van warms up and goes into higher speeds and from what I have learned the viscous coupling works on the basis of the fluid heating up and helping it transfer power to the front and back.
Any thoughts or ideas on this?
sxfx
Postby curtisbobbie » January 9th 2010, 9:27pm
I'm not much of an expert on AWD but I can tell you that if you have a different gear ratio in the front and back differentials, something is going to give, break. It might be a differential, drive shaft, transfer case. But something will eventually go.
curtisbobbie
Years of Membership: curtisbobbie has been a member for 10 full yearscurtisbobbie has been a member for 10 full yearscurtisbobbie has been a member for 10 full yearscurtisbobbie has been a member for 10 full yearscurtisbobbie has been a member for 10 full yearscurtisbobbie has been a member for 10 full yearscurtisbobbie has been a member for 10 full yearscurtisbobbie has been a member for 10 full yearscurtisbobbie has been a member for 10 full yearscurtisbobbie has been a member for 10 full years
Topics: 5
Extra Info: 4.3 AUTO AWD
Postby Tygre II » January 13th 2010, 7:00am
sxfx,
Did you get a chance to check to see if your new front differential is different from your old one?
That would make the system fight itself.
Did you get the problem fixed? If so, then what was the problem and what was the fix?
Tygre II
Fueling (7/8 tank)
Fueling (7/8 tank)
Years of Membership: Tygre II has been a member for 11 full yearsTygre II has been a member for 11 full yearsTygre II has been a member for 11 full yearsTygre II has been a member for 11 full yearsTygre II has been a member for 11 full yearsTygre II has been a member for 11 full yearsTygre II has been a member for 11 full yearsTygre II has been a member for 11 full yearsTygre II has been a member for 11 full yearsTygre II has been a member for 11 full yearsTygre II has been a member for 11 full years
Postby offroad safari » January 13th 2010, 2:14pm
the first thing i would do is take out the front drive shaft and go for a drive. this will elminate any problems with the rear differential. let me know if the whine goes away. and having a front diff with a different gear ratio would be definately kill a transfer case and other driveline components
'90 AWD Shorty Safari
4" Overland Lift + countless mods
"It's a Safari thing.... Jeep people couldn't understand"
offroad safari
Years of Membership: offroad safari has been a member for 11 full yearsoffroad safari has been a member for 11 full yearsoffroad safari has been a member for 11 full yearsoffroad safari has been a member for 11 full yearsoffroad safari has been a member for 11 full yearsoffroad safari has been a member for 11 full yearsoffroad safari has been a member for 11 full yearsoffroad safari has been a member for 11 full yearsoffroad safari has been a member for 11 full yearsoffroad safari has been a member for 11 full yearsoffroad safari has been a member for 11 full years
Topics: 19
Alias (AKA): Witman40
Extra Info: AWD Shorty
Return to Uncategorized
It is currently December 2nd 2020, 1:50pm
Uncategorized Forum
foxfire
in Uncategorized
Comments: 16275
Date: Nov 30 '20
Time: 2:25am
Attached by: chevymaher
in Uncategorized
Date: Nov 28 '20
Time: 5:28pm
in Uncategorized
Date: Nov 28 '20
Time: 4:01pm
in Uncategorized
Comments: 16275
Date: Nov 27 '20
Time: 6:33pm
Attached by: icebrrg3rd
icebrrg3rd
in Uncategorized
Comments: 16275
Date: Nov 24 '20
Time: 5:55pm
Users browsing this forum: Google [Bot] and 3 guests
