PLEASE HELP. BAD GAS MILEAGE
Postby 98-ASTRO-SS [OP] » February 4th 2010, 3:11am
I have a 98 Astro w/ 68,000 original miles. The only mods I have done to it is a K&N replacement filter & 20" wheels w/ 245-35-20 all around. I bought the van with 52,000 miles about 8 months ago. When I first got the van I avg. 16-17.5 mpg now Im down to 8-9 mpg. The van still runs great, idles great, no codes are coming up. Just changed the plugs & the old ones where fine but changed them anyway. My mechanic can not find any leaks anywhere & he & I are dumbfounded on the whole problem. My wife drives the van & is bothering me to death about this problem. I hope yall can help me with this problem if not I will be trading it in & getting some other vehicle. Other thing that may help is the spedo is broke but does not affect the rpm's any & the problem started as soon as I got my oil changed at super lube to go on a trip & as soon as I left getting the oil changed my spedo broke & gas mileage fell . PLEASE HELP :banghead: :feedback: :confused: :shrug: :crying:
98-ASTRO-SS
Years of Membership: 98-ASTRO-SS has been a member for 11 full years98-ASTRO-SS has been a member for 11 full years98-ASTRO-SS has been a member for 11 full years98-ASTRO-SS has been a member for 11 full years98-ASTRO-SS has been a member for 11 full years98-ASTRO-SS has been a member for 11 full years98-ASTRO-SS has been a member for 11 full years98-ASTRO-SS has been a member for 11 full years98-ASTRO-SS has been a member for 11 full years98-ASTRO-SS has been a member for 11 full years98-ASTRO-SS has been a member for 11 full years
Extra Info: 4.3L RWD
  • checking mileage on junk yard vans
    by Rod's Trucks » November 19th 2020, 4:41am in Electrical
    Last post by stent View the latest post
    December 5th 2020, 5:29pm
  • 1995 GMC Safari HWY Beast! But poor fuel mileage..
    by 95SafariRunner » January 31st 2021, 10:16am in Engines
    February 2nd 2021, 8:13pm
    February 25th 2021, 12:29pm
Re: PLEASE HELP. BAD GAS MILEAGE
Postby $uperJoe » February 4th 2010, 3:20am
i would check the connection at the vss in the tail of the trans for a loose or broken wire. there are 4 modes that the engine will work in. warm up, low idle, traffic, and cruise. each mode has different fuel mapping. if the pcm does not see any speed it will always dump fuel in the motor as if in warm up or easier to understand "choke"mode for you carb guys. the speedo is vital to fuel mapping
Check out my Van build
$uperJoe
Firing on 4 Cylinders (L2)
Years of Membership: $uperJoe has been a member for 11 full years$uperJoe has been a member for 11 full years$uperJoe has been a member for 11 full years$uperJoe has been a member for 11 full years$uperJoe has been a member for 11 full years$uperJoe has been a member for 11 full years$uperJoe has been a member for 11 full years$uperJoe has been a member for 11 full years$uperJoe has been a member for 11 full years$uperJoe has been a member for 11 full years$uperJoe has been a member for 11 full years
Topics: 59
Postby 98-ASTRO-SS [OP] » February 4th 2010, 3:28am
But wouldnt that make it idle high? It idles perfect
98-ASTRO-SS
Postby rev_les » February 4th 2010, 3:37am
Yeah, it's an odd problem, if it has no VSS signal, it shouldn't shift.Does the temp gauge show that it's coming up to operating temperature?
NRA Lifetime Member
2'nd amendment supporter
'13 Jeep Patriot
'87 Monte Carlo SS
'79 Avco 32' RV
rev_les
Firing on 2 Cylinders (L3)
Years of Membership: rev_les has been a member for 12 full yearsrev_les has been a member for 12 full yearsrev_les has been a member for 12 full yearsrev_les has been a member for 12 full yearsrev_les has been a member for 12 full yearsrev_les has been a member for 12 full yearsrev_les has been a member for 12 full yearsrev_les has been a member for 12 full yearsrev_les has been a member for 12 full yearsrev_les has been a member for 12 full yearsrev_les has been a member for 12 full yearsrev_les has been a member for 12 full years
Topics: 39
Alias (AKA): Les
Extra Info: LS 4.3 RWD
Postby 98-ASTRO-SS [OP] » February 4th 2010, 3:48am
it shifts fine. it doesnt smoke like its getting to much fuel or anything. I even run 93 octane & it doesnt help. Everything works just as good as when I got the van but now it gets about 9mpgs rather than 16-17. My mechanic is not a shade tree mech either if any of yall are thinking that. Its a pro full service auto shop. In other terms of mpgs It did get about 375 miles to a tank and now it gets 180-200
98-ASTRO-SS
Postby rev_les » February 4th 2010, 4:20am
if the engine's not coming up to operating temperature,the computer will keep it rich, causing bad fuel mileage, that's why I'm asking about that.If the catalytic converter is working correctly, an engine can even be burning some oil and not smoke, so no smoke isn't a reliable indicator.
NRA Lifetime Member
'13 Jeep Patriot
'87 Monte Carlo SS
'79 Avco 32' RV
rev_les
Topics: 39
Alias (AKA): Les
Postby 98-ASTRO-SS [OP] » February 4th 2010, 4:43am
It comes up to operating temp just fine it has a low temp thermostat. I belive its 180 but it comes up to operating temp as it normally does. Thanks
98-ASTRO-SS
Postby Leeann_93 » February 4th 2010, 5:06am
98-ASTRO-SS wrote:It comes up to operating temp just fine it has a low temp thermostat. I belive its 180 but it comes up to operating temp as it normally does. Thanks
180° isn't operating temp for these vehicles. 195° is. One of the side affects of running cool is reduced gas mileage.
Postby Astroplane » February 4th 2010, 10:02am
Were there any other services to the van at the time of the oil change? Any info on what weight oil they used? Was the van put on a lift for the oil change? You sound convinced that the poor fuel economy began right around the time of the service. Also, what do the Fuel Trims show in engine data?
Astroplane
Blue Status (L2)
Blue Status (L2)
Years of Membership: Astroplane has been a member for 11 full yearsAstroplane has been a member for 11 full yearsAstroplane has been a member for 11 full yearsAstroplane has been a member for 11 full yearsAstroplane has been a member for 11 full yearsAstroplane has been a member for 11 full yearsAstroplane has been a member for 11 full yearsAstroplane has been a member for 11 full yearsAstroplane has been a member for 11 full yearsAstroplane has been a member for 11 full yearsAstroplane has been a member for 11 full years
Extra Info: LT RWD
Postby astro355 » February 4th 2010, 10:11am
I would clean your MAF sensor. I see your running a K&N filter. MAF sensors can get "covered" with the oil from a K&N filter and that will throw the readings off.
Also, the ECM needs a vehicle speed for its fuel maps. You should be able to hook a scan tool up to the drive and take a test drive to test what part of the speed isn't working. If the connect between the trans is ecm is at fault, you will not be able to see a vehicle speed reading on the scan tool. If you can, then something between the ecm and instrument cluster is at fault. And the lack of a VSS signal will not affect your idle. While you're stopping and the van idling, your speed is 0 mph. And once you start moving, the van will work at other inputs such as load (MAF, MAP, etc).
astro355
Firing on 4 Cylinders (L6)
Extra Info: 355 V8 700R4
Postby 98-ASTRO-SS [OP] » February 4th 2010, 12:57pm
It has had the low temp stat on it since I bought it
98-ASTRO-SS
Postby 98-ASTRO-SS [OP] » February 4th 2010, 1:00pm
Astroplane wrote:Were there any other services to the van at the time of the oil change? Any info on what weight oil they used? Was the van put on a lift for the oil change? You sound convinced that the poor fuel economy began right around the time of the service. Also, what do the Fuel Trims show in engine data?
It was only a oil change & it was not on a lift . I belive the oil was 5-30 or 10-30 Mobil 1 Synthetic. How do I even check the fuel trims in the engine data?
98-ASTRO-SS
Postby 98-ASTRO-SS [OP] » February 4th 2010, 1:04pm
astro355 wrote:I would clean your MAF sensor. I see your running a K&N filter. MAF sensors can get "covered" with the oil from a K&N filter and that will throw the readings off.
I will check that out. Thanks
98-ASTRO-SS
Postby Astroplane » February 5th 2010, 6:03am
98-ASTRO-SS wrote:How do I even check the fuel trims in the engine data?
Your mechanic will know how to read that on the scanner.
Astroplane
Blue Status (L2)
Blue Status (L2)
Extra Info: LT RWD
Postby [email protected] » August 3rd 2014, 3:21pm
I think this will help shed some light on gas mileage for the Astro vans.I Bought my 2002 Astro van in 2007 with 45000 miles and great shape. The van now has 248,000 miles and the fuel mileage has fallen off in the past year. 12-14 on the highway and about 10 MPG in the city. I drive A LOT of highway miles towing a small 5 X 8 trailer. Towing i am getting about 9-10 mpg.My gas mileage was 17-19 on the highway, 12- 14 in the city. I have replaced the tires 3times - the original tires were P215/75R15. I replaced the tires 2 time with P225/70R15 for a better ride and appearance. my gas mileage stayed 17-19 and 12-14 hwy/city. The 3 rd time i replaced the tires I bought tires on sale for a great deal. they were 235/75R15 all terrain tires. My gas mileage dropped to 11 on the highway and 8 when i was towing a trailer. additionally the transmission shifted back and forth from OD to 3rd and i notice the engine labored a lot more due the additional size of the tires. Thankfully the tire shop allowed my to exchange the tires for a different tire. the replacement tires are P225/78R15. I think this explains why my gas mileage has dropped to what it is now. My next tires will be P225/70R15 and hopefully the gas mileage will go back to normal.Sorry this is so lengthy but i wanted to explain my point and what I have experienced.
[email protected]
Years of Membership: chipnbud@yahoo.com has been a member for 6 full yearschipnbud@yahoo.com has been a member for 6 full yearschipnbud@yahoo.com has been a member for 6 full yearschipnbud@yahoo.com has been a member for 6 full yearschipnbud@yahoo.com has been a member for 6 full yearschipnbud@yahoo.com has been a member for 6 full years
Alias (AKA): Chip
Van Model Year: 2002
Postby Leeann_93 » August 4th 2014, 1:52am
You did notice that the last post was 4 years ago, yes?
Postby kmtechman1 » August 4th 2014, 2:26am
This problem should not be that hard to find. Drive the van for 20 minutes and see if you have a wheel hot from stuck, dragging brake caliper or rusty failure to release emengency brake. Change the fuel filter and drain the old one into a clear jar so you can see if it looks milky, it had water in it. I replaced a fuel pump one time and found 5 pounds of sugar in the gas tank. The guy had enemys, I guess. Ken
kmtechman1
Years of Membership: kmtechman1 has been a member for 6 full yearskmtechman1 has been a member for 6 full yearskmtechman1 has been a member for 6 full yearskmtechman1 has been a member for 6 full yearskmtechman1 has been a member for 6 full yearskmtechman1 has been a member for 6 full years
Topics: 5
Alias (AKA): Ken
Postby Leeann_93 » August 4th 2014, 2:28am
Again, this thread is 4 and a half years old. Please let it die.
Postby Grimspyder » September 29th 2014, 12:32pm
Don't let it die! This answered some questions and the last post, actually was good info.
97 AWD 4.3L V6 Discovery, Automatic Transmission, Seats 7, 167,000 miles.
Grimspyder
Years of Membership: Grimspyder has been a member for 9 full yearsGrimspyder has been a member for 9 full yearsGrimspyder has been a member for 9 full yearsGrimspyder has been a member for 9 full yearsGrimspyder has been a member for 9 full yearsGrimspyder has been a member for 9 full yearsGrimspyder has been a member for 9 full yearsGrimspyder has been a member for 9 full yearsGrimspyder has been a member for 9 full years
Extra Info: AWD Discovery V6
Postby catbones » September 29th 2014, 1:51pm
I've got 100 to 200 about 6 months ago and depending on a fill up when my fuel pump was going out of service. It didn't show any signs of being bad other then a bad mileage and then it took about 3 moths or so for it to get bad idle once in a long while.
After new fuel pump I was able to get 350 a tank. Maybe that will help.
catbones
Years of Membership: catbones has been a member for 7 full yearscatbones has been a member for 7 full yearscatbones has been a member for 7 full yearscatbones has been a member for 7 full yearscatbones has been a member for 7 full yearscatbones has been a member for 7 full yearscatbones has been a member for 7 full years
Topics: 83
Alias (AKA): catbones
Extra Info: Base 4.3L V6 AWD
Return to Uncategorized
It is currently February 25th 2021, 12:29pm
Uncategorized Forum
Attached by: icebrrg3rd
icebrrg3rd
in Uncategorized
Comments: 2995
Date: Feb 23 '21
Time: 6:27pm
in Uncategorized
Comments: 16418
Date: Feb 16 '21
Time: 8:08pm
Coronavan
in Uncategorized
Comments: 235
Date: Feb 14 '21
Time: 4:06am
Upstatevanvibes
in Uncategorized
Date: Feb 14 '21
Time: 3:20am
Coronavan
in Uncategorized
Date: Feb 14 '21
Time: 1:18am
Users browsing this forum: Google [Bot] and 9 guests
