Bosch O2 Sensors
Bosch O2 Sensors
Postby mngcornaglia [OP] » June 17th 2010, 10:33pm
I installed new bosch sensors as part of a tune-up at 68K miles. since i've got OBDII codes for "O2 Heater Resistance". Called Bosch tech support. On 3rd call, tech finally admitted to known problems with GM 4.3 Vans only. On cold start, system checks resistance of O2 heaters. My computer wants 3.6 ohms cold, the bosch units were 8.3 (left) and 10.1 (both on right side) ohms. Bosch is working a fix, but doubt it will come in my lifetime on an out-of-production vehicle.
Bosch Tech recommended use of OEM or another brand O2. Chevy wants $200 each. Sparkplug.com had Densos on sale for $57 each. They are in the mail. If they aren't 3.6 ohms or something that works, the other option is NGK.
I read others have had a similar problem, so i wanted to save anyone else some of the same headaches.
mngcornaglia
Years of Membership: mngcornaglia has been a member for 10 full yearsmngcornaglia has been a member for 10 full yearsmngcornaglia has been a member for 10 full yearsmngcornaglia has been a member for 10 full yearsmngcornaglia has been a member for 10 full yearsmngcornaglia has been a member for 10 full yearsmngcornaglia has been a member for 10 full yearsmngcornaglia has been a member for 10 full yearsmngcornaglia has been a member for 10 full yearsmngcornaglia has been a member for 10 full years
Re: Bosch O2 Sensors
Postby Leeann_93 » June 18th 2010, 12:02am
You can get AC Delco from rockauto.com, btw - I just got one for my van.
Postby LEVE » June 18th 2010, 1:14am
Thanks for the information. It's one I'd have missed, I usually only buy Bosh O2 Sensors. :doh:
LEVE
Years of Membership: LEVE has been a member for 10 full yearsLEVE has been a member for 10 full yearsLEVE has been a member for 10 full yearsLEVE has been a member for 10 full yearsLEVE has been a member for 10 full yearsLEVE has been a member for 10 full yearsLEVE has been a member for 10 full yearsLEVE has been a member for 10 full yearsLEVE has been a member for 10 full yearsLEVE has been a member for 10 full years
Topics: 18
Extra Info: AWD 4.3L-W
Postby sfeaver » June 18th 2010, 2:48am
OEMs i bought two years ago for a 98 model were made by denso.
Scott
sfeaver
Firing on 8 Cylinders (L1)
Topics: 29
Images: 21
Van Model Year: 2001
Extra Info: LT RWD 350ci V8
Postby rev_les » June 18th 2010, 3:58am
Hmm :think: .that explains a lot, especially the constant HO2 sensor codes I get, and have been getting for years. ( I have Bosch sensors) Now I'll have to see if adding a few ohms of resistance helps out :D
NRA Lifetime Member
2'nd amendment supporter
'13 Jeep Patriot
'87 Monte Carlo SS
'79 Avco 32' RV
rev_les
Firing on 2 Cylinders (L3)
Topics: 39
Alias (AKA): Les
Extra Info: LS 4.3 RWD
Postby jeff's93astro » June 18th 2010, 4:13am
so would denso be a good replacement. because i cant see giving $90 for the ac delco sensor and thats on rockauto
95 Astro 5.3L RWD 3/3 drop
03 Suburban 5.3L 2wd 3/5 drop
jeff's93astro
Topics: 55
Images: 19
Extra Info: CS 4.3L V6 RWD
Postby Astroplane » June 18th 2010, 9:04am
mngcornaglia wrote:I installed new bosch sensors as part of a tune-up at 68K miles. since i've got OBDII codes for "O2 Heater Resistance".
Were there codes present prior to the replacement? I don't think O2 sensors are part of a tune-up on a OBDII van with 68K.
Astroplane
Blue Status (L2)
Blue Status (L2)
Years of Membership: Astroplane has been a member for 10 full yearsAstroplane has been a member for 10 full yearsAstroplane has been a member for 10 full yearsAstroplane has been a member for 10 full yearsAstroplane has been a member for 10 full yearsAstroplane has been a member for 10 full yearsAstroplane has been a member for 10 full yearsAstroplane has been a member for 10 full yearsAstroplane has been a member for 10 full yearsAstroplane has been a member for 10 full years
Extra Info: LT RWD
Postby Matrixx » June 18th 2010, 10:02am
Hi mngcornaglia
Hmm, odd. I run Bosch in my van and have never had a problem (11 years now). Maybe GM added tighter O2 parameters in the later models.
That's very good information to know mngcornaglia thanks.:)
Matrixx
Postby mngcornaglia [OP] » June 18th 2010, 5:59pm
CORRECTION: the system wants 3.6 ohms (not 13 previously stated). this problem has been making me nuts for over a month - checking connections, fuses, grounds, talking to the Bosch techs who said, "we make millions of sensors, must be your car". Finally talked to one (Adam) who was honest. Bosch tech line: 888-715-3616.
mngcornaglia
Postby astroturf » June 18th 2010, 6:06pm
mngcornaglia wrote:CORRECTION: the system wants 3.6 ohms (not 13 previously stated). this problem has been making me nuts for over a month - checking connections, fuses, grounds, talking to the Bosch techs who said, "we make millions of sensors, must be your car". Finally talked to one (Adam) who was honest. Bosch tech line: 888-715-3616.
Do you still have the stock ones?
astroturf
Topics: 112
Extra Info: 2wd Passenger
Postby mngcornaglia [OP] » June 19th 2010, 3:14am
rev_les wrote:Hmm :think: .that explains a lot, especially the constant HO2 sensor codes I get, and have been getting for years. ( I have Bosch sensors) Now I'll have to see if adding a few ohms of resistance helps out :D
rev_les, there's a correction on those ohms. should have 3.6 not the 13 previously stated....
mngcornaglia
Postby rev_les » June 20th 2010, 4:09am
Yeah, I caught that....now I'm gonna have to re-plan , or just buy the Denso's I've been thinking about, lol...thanks for the correction!
NRA Lifetime Member
'13 Jeep Patriot
'87 Monte Carlo SS
'79 Avco 32' RV
rev_les
Topics: 39
Alias (AKA): Les
Return to Uncategorized
It is currently January 23rd 2021, 5:48pm
Uncategorized Forum
in Uncategorized
Comments: 17
Time: 12:56am
in Uncategorized
Comments: 17
Date: Jan 21 '21
Time: 10:23pm
Rockridge
in Uncategorized
Comments: 2980
Date: Jan 19 '21
Time: 12:03am
Ram
in Uncategorized
Comments: 17
Date: Jan 17 '21
Time: 6:51pm
in Uncategorized
Comments: 16380
Date: Jan 14 '21
Time: 3:29am
