really only ONE diesel swap?
Postby biggreenoger [OP] » September 13th 2010, 12:57am
So as I have lurked around this site I have only seen one attempt at a diesel swap? Only 1 that has a drivable diesel Astro/Safari. With so many makers of these robust engines out there I'm a little surprised. I know room is limited but can't you just feel the tire burning torque, and great milage of 2.73 gears? Anyone toying with the idea? think of the possibilities... :whistle:
Life's a GAS, It can at times make you laugh or smell real BAD!
biggreenoger
Years of Membership: biggreenoger has been a member for 10 full yearsbiggreenoger has been a member for 10 full yearsbiggreenoger has been a member for 10 full yearsbiggreenoger has been a member for 10 full yearsbiggreenoger has been a member for 10 full yearsbiggreenoger has been a member for 10 full yearsbiggreenoger has been a member for 10 full yearsbiggreenoger has been a member for 10 full yearsbiggreenoger has been a member for 10 full yearsbiggreenoger has been a member for 10 full years
Topics: 7
Alias (AKA): Jake
Extra Info: 4x4 1Ton Cummins
  • Diesel heater exhaust
    by copperhead » October 13th 2020, 2:29am in Climate Control
    Last post by Astrocurious View the latest post
    October 20th 2020, 11:47am
  • 99 swap to 01 motor and trans? Or LV3 & 6l80 swap?
    by kade225 » October 28th 2020, 11:38pm in Engines
    Last post by stent View the latest post
    October 30th 2020, 9:53am
    November 30th 2020, 11:42pm
Re: really only ONE diesel swap?
Postby hardlecure » September 13th 2010, 2:41am
i think about it regularly but I'm unsure of any available Duramax that will be able to fit in the Vortec's place. I know if and when Chevy wises up and releases the 4.5L Duramax I'll be one of the first in line at the dealership to buy the motor, allison tranny, ecm, tcm and a eaton posi. But until then I'll stick with the 4.3
A$$, Gas or Grass.... Nobody Rides For Free
hardlecure
Years of Membership: hardlecure has been a member for 10 full yearshardlecure has been a member for 10 full yearshardlecure has been a member for 10 full yearshardlecure has been a member for 10 full yearshardlecure has been a member for 10 full yearshardlecure has been a member for 10 full yearshardlecure has been a member for 10 full yearshardlecure has been a member for 10 full yearshardlecure has been a member for 10 full yearshardlecure has been a member for 10 full years
Extra Info: One Wheel Peel
Postby biggreenoger [OP] » September 13th 2010, 3:17am
Oh ya the D-max, Great engine and very capable of impressive numbers all the way. From fuel mileage to power it really stands out. With dimensions and weight just ever so greater than a big block chevy it could work. But as for price well, bet you could get a small block to run on water for less. Hows about a UD trucks 4.2L I-6 banger( Nissan I think), Isuzu's( maker of the D-max) 3.0L 4J or the 5.2L 4H. These are fairly comparable t the size of a v-8.
biggreenoger
Topics: 7
Alias (AKA): Jake
Postby hardlecure » September 13th 2010, 12:37pm
The Isuzu D-Max 3.0 L has less power and torque than the 4.3 so it's not worth the cost to get one. As for the Nissan... I wont touch/own/drive anything that doesn't have a bowtie on it and I certainly wont taint a Chevy with some foreign engine.
hardlecure
Postby biggreenoger [OP] » September 13th 2010, 4:09pm
In 1991, the limited-edition GMC Syclone featured a 280 hp and 350 lb·ft turbocharged and intercooled LB4 with the first use of multi-point fuel injection on a 4.3L Vortec V6. Power output of the new LU3/LG3 engines is 180 hp to 200 hp and 245 lb·ft to 260 lb·ft.
Now this is a newer engine, so I agree its spendy$$$$$$$$
4JJ1-TC produce 150 horsepower and 282 lbs.-ft. of torque. Despite its spirited performance, this engine is a miser. In fact, the NPR ECO-MAX achieves up to 20% better fuel economy. Like every Isuzu powerplant, the 4JJ1-TC is a true commercial vehicle engine. Each component has been crafted to reduce maintenance and increase durability.
So it’s no surprise that the 4JJ1-TC can be driven up to 10,000 miles between oil changes and has a class-leading B10 durability rating of 310,000 miles—meaning that 90% of 4JJ1-TC engines will reach that mileage before requiring an overhaul.
Torque is what gets you moveing.
biggreenoger
Topics: 7
Alias (AKA): Jake
Postby biggreenoger [OP] » September 13th 2010, 4:10pm
All said and done, Its just cuz the chicks dig it.....
biggreenoger
Topics: 7
Alias (AKA): Jake
Postby biggreenoger [OP] » September 14th 2010, 2:22am
hows about stuffing this in a astro? :whistle:
biggreenoger
Topics: 7
Alias (AKA): Jake
Postby d0nk3y » September 14th 2010, 7:57pm
I think a fresh 6.2L would be a bolt-in affair.
Back in "the day", you could get nearly 30 mpg in a 6.2L 2wd Suburban. Not sure if there is room for boost, but it would be an interesting setup for sure. :)
Best MPG to date:
21.0
d0nk3y
Fueling (3/4 tank)
Fueling (3/4 tank)
Years of Membership: d0nk3y has been a member for 10 full yearsd0nk3y has been a member for 10 full yearsd0nk3y has been a member for 10 full yearsd0nk3y has been a member for 10 full yearsd0nk3y has been a member for 10 full yearsd0nk3y has been a member for 10 full yearsd0nk3y has been a member for 10 full yearsd0nk3y has been a member for 10 full yearsd0nk3y has been a member for 10 full yearsd0nk3y has been a member for 10 full years
Topics: 9
Alias (AKA): Scooter
Extra Info: LT AWD
Postby Dirk » September 14th 2010, 8:30pm
biggreenoger wrote:hows about stuffing this in a astro? :whistle:
How about this: it a damn Mopar engine! :rofl: :rofl:
The only Mopar engine I would ever drop in a Chevy is the 528 hemi.
If I had to choose between a Cummins or the new D-max I would go with the new D-max because I like the numbers better.
@ donkey: the 6.5 turbo charged V8 diesel will fit just as well.
1985 Astro conversion, engine type N 4.3 4BBL
If you can't fix it with a hammer you've got an electrical problem!
Parts are cheap breakdowns expensive.
Don't worry about miles per gallon, worry about smiles per gallon!
Dirk
Firing on 8 Cylinders (L1)
Years of Membership: Dirk has been a member for 10 full yearsDirk has been a member for 10 full yearsDirk has been a member for 10 full yearsDirk has been a member for 10 full yearsDirk has been a member for 10 full yearsDirk has been a member for 10 full yearsDirk has been a member for 10 full yearsDirk has been a member for 10 full yearsDirk has been a member for 10 full yearsDirk has been a member for 10 full years
Images: 11
Extra Info: 4.3L 4BBL
Postby biggreenoger [OP] » September 15th 2010, 2:29am
:naughty: Cummins is not a Dodge engine, but maybe the only reason to own one. It is an Industrial engine the has a proven back ground, and is found in almost every make from Chevy, Ford, Dodge to International. Mine tho did come out of a Ram 2500 :oops: It will loose the Dodge rocker cover too.
Well the 6.2, and 6.5 are a real clear choice as for drop in bolt up and go. The 6.2 (especially the 1982 the stongest block) are still plentifull as the US Military ran them in almost all GM light trucks and hmmvees and still have hundreds in crates. Humm a twin turbo 6.2 and a built 700r...I know a guy that has a retired 1009 K5 blazer on 37" humvee tires and he claims 30+mpg. The 6.5 is based on all most the same block so it should fit nicely also. I think I saw a build that someone started with an Astro getting a 6.2. I try to dig it up. The Duramax is very impressive all the way down to all of it elctronics. To play D-max one would need DEEP pokets.
biggreenoger
Topics: 7
Alias (AKA): Jake
Postby biggreenoger [OP] » September 15th 2010, 3:27am
This was all I could find on that 6.2 swap. I'm thinking its a Th400 on the back side, but deff a astro frame section. The last time he posted anything was in '07 but nothing after these pics.
6.2 astro.jpg (153.13 KiB) Viewed 2710 times
6.2 astro.jpg (98.32 KiB) Viewed 2710 times
biggreenoger
Topics: 7
Alias (AKA): Jake
Postby Gary » September 15th 2010, 3:59am
Just for the record-not the only diesel swap.
viewtopic.php?f=68&t=6981
It's listed right at the bottom of your thread in similar topics.
Also-about a year ago a guy posted he worked for a company in South America who bought second hand new builds diesel Astro's that GM sub'ed to Japan to build.They have a fleet of them with the original window stickers that included the extra charges for the diesels.BTW-that post is not on this site.
The early "want-to-be' Olds diesels where pcs of junk.I owned one and the one thing they are noted for is cracked heads and blown head gaskets.Heavy walled blocks that had a wt unwarranted for their intended use with junk heads,head gaskets, and a valve train I wouldn't want to wish on my worse enemy. :banghead:
Should you be proud of your build??I am saying you bet.Well done.The first and only one????.Doesn't seem so........ just for the record.
Gary
Dearly Departed
Firing on 4 Cylinders (L3)
Topics: 136
Extra Info: high top
Postby biggreenoger [OP] » September 15th 2010, 4:37am
Oh no, I would not say mine is a is a sucessful swap since i used a full size blazer 4x4 frame. But some where i found a guy who had a Iveco 3.9 diesel in his astro and had road worthy miles on it. My van is just one of those "I had an itch in need of a scratch" cuz I can things. But I'll have to look those other JDM vans up for the specs on them.
EDIT: Ya thats the one that i was talking about.....Iveco 3.9 liter turbo diesel. (same size as Cummins)
biggreenoger
Topics: 7
Alias (AKA): Jake
Postby Gary » September 15th 2010, 5:18am
Well using a blazer frame answers questions on another thread too.It does add tons to the look of the van.Excuse me for the term,but it is just a ***** look that doesn't quit and with a diesel no less.Well done in deed. :bow: :bow: :clap: :clap:
Forgot to ask,what front/rear end gears are you running??.
:lol: :lol: seems the censors cut my comment......well what's a old hot rodder to do........ :doh: :doh:
Gary
Dearly Departed
Topics: 136
Postby loopie » September 15th 2010, 9:55am
biggreenoger wrote:All said and done, Its just cuz the chicks dig it.....
Chicks dig a V8 gasser. Every time, all the time. Unless they're particularity hairy.
loopie
Years of Membership: loopie has been a member for 11 full yearsloopie has been a member for 11 full yearsloopie has been a member for 11 full yearsloopie has been a member for 11 full yearsloopie has been a member for 11 full yearsloopie has been a member for 11 full yearsloopie has been a member for 11 full yearsloopie has been a member for 11 full yearsloopie has been a member for 11 full yearsloopie has been a member for 11 full yearsloopie has been a member for 11 full years
Topics: 19
Alias (AKA): Loopie
Postby biggreenoger [OP] » September 15th 2010, 11:58pm
:shifty: :lol: :lol: :clap: WOW, I think I just got schooled!! Well played. I like a site with fellow wise a*s's! :clap: :clap:
self censored
biggreenoger
Topics: 7
Alias (AKA): Jake
Postby Gary » September 16th 2010, 2:17am
Just hairy????.Viking chick with hairy,ink,and heavy metal around her neck and a horn hat.yo ho yo ho. :eek: :eek: :eek:
Gary
Dearly Departed
Topics: 136
Postby cowboydan » September 16th 2010, 2:26am
i know gm use to put the 6.5 or the 6.2 into many half tons of the 80s' and i was a proud hand-me-down owner of an 82 cutlas diesel. though none of these were ever turbo. i found them all to be lacking in power. installing a new turbo diesel would pose alot of driveline issues and i havn't seen any diesels in less than 3/4 ton. so i would say that a diesel swap would cost alot more because to get reliability, you would want to change the whole driveline. not saying you shouldn't entertain just the engine/tranny.
2006 sebring 2.7 touring: DD
cowboydan
Firing on 8 Cylinders (L2)
Topics: 67
Alias (AKA): cbd
Extra Info: 4.3w CL AWD
Postby biggreenoger [OP] » September 16th 2010, 5:31am
Gary wrote:Well using a blazer frame answers questions on another thread too.It does
I have 4:11 gears front and rear. The front axle is a dana 60 hi-pinon out of a '78 f-350 camper special the rear is a dana 70HD out of a '79 chevy 1.25 ton. it sits right now on 38's but i have plans for large 35" drag slicks to show off with. Np 205 iron transfer case to connect the diffs. Waiting for the trans to come back from the builder, and then off to get some drivshafts..
The Military ran the 6.2 in all GM light trucks and even the humvee all the way till 1990 i think. After that the humvee got the 6.5td and now they have the D-max. I agree that the first gm diesel are best used for anchors, but the '82 and up take to a turbo like a pig to mud. I once had the ill fated ownership of a '80 heavy half with a diesel that could bearly pull its self. But I do have a buddy ownes a retired 1987 military 1009 blazer with the 6.2 and 37" humvee tires still NA but turned the fuel up and loves that truck. And that pile gets almost 30MPGs.
biggreenoger
Topics: 7
Alias (AKA): Jake
Postby doyoulikeithere » September 16th 2010, 5:54am
Deep pockets for sure.
I happened to look at the price of a brand new GMC 1 ton duramax Pickup, and it was nearly 80 grand, before tax and dealer BS.
I didnt bother to look at the new Vette's pricetag as it just seemed to depressing, sigh.....
:twisted:
doyoulikeithere
Firing on 7 Cylinders (L1)
Years of Membership: doyoulikeithere has been a member for 12 full yearsdoyoulikeithere has been a member for 12 full yearsdoyoulikeithere has been a member for 12 full yearsdoyoulikeithere has been a member for 12 full yearsdoyoulikeithere has been a member for 12 full yearsdoyoulikeithere has been a member for 12 full yearsdoyoulikeithere has been a member for 12 full yearsdoyoulikeithere has been a member for 12 full yearsdoyoulikeithere has been a member for 12 full yearsdoyoulikeithere has been a member for 12 full yearsdoyoulikeithere has been a member for 12 full yearsdoyoulikeithere has been a member for 12 full years
Topics: 26
Images: 11
Return to Uncategorized
It is currently November 30th 2020, 11:42pm
Uncategorized Forum
foxfirefoxfire is online!
in Uncategorized
Comments: 16268
Date: Today
Time: 2:25am
Attached by: chevymaher
in Uncategorized
Date: Nov 28 '20
Time: 5:28pm
in Uncategorized
Date: Nov 28 '20
Time: 4:01pm
MmusicmanMmusicman is online!
in Uncategorized
Comments: 16268
Date: Nov 27 '20
Time: 6:33pm
Attached by: icebrrg3rd
icebrrg3rd
in Uncategorized
Comments: 16268
Date: Nov 24 '20
Time: 5:55pm
Users browsing this forum: foxfirefoxfire is online! and 5 guests
