the nightmare begins....
Postby damnadodge [OP] » April 9th 2016, 1:44am
well this isn't an astro, but i thought i would give y'all a stab at it anyway since you's all's have been so helpful in the past :D ....here goes. i got an 1993 chevy conversion van, not a high top and a short wheelbase. my estute landlord was doing his yearly hiring of the lawn crew for the 3 grass cuts we get a year, and one of the fine lawn technicians thought it was a good idea to move from yard to yard via the gravel parking lot in between without shutting off the mower....thats right, as you can probably guess i was the lone recipient of a rock to the window. now that i have researched the window, i cant seem to find anyone to tackle it without some serious difficulty. i might try to do it myself, but i cannot figure out how to get the window out of the frame. i could just get someone to make a glass if i can just get it in the frame. its one of those aluminum frames with one seam at the top. and of course they do not make the whole frame with the glass in it anymore in that size. thanks in advance
steve
5472254714547065469854690546745466654658546505464254634
damnadodge
Years of Membership: damnadodge has been a member for 8 full yearsdamnadodge has been a member for 8 full yearsdamnadodge has been a member for 8 full yearsdamnadodge has been a member for 8 full yearsdamnadodge has been a member for 8 full yearsdamnadodge has been a member for 8 full yearsdamnadodge has been a member for 8 full yearsdamnadodge has been a member for 8 full years
Topics: 26
Images: 72
Van Model Year: 1990
  • And so it begins, my van build
    by mglsite » October 17th 2020, 11:02pm in Projects/Builds
    Last post by mglsite View the latest post
    October 18th 2020, 12:36am
    February 28th 2021, 2:00pm
Re: the nightmare begins....
Postby Lumpy » April 9th 2016, 1:46am
The glass company that your landlord's insurance company hires should have no trouble.
Postby damnadodge [OP] » April 9th 2016, 1:50am
neither of us did the insurance thing. i did not file a claim with mine because i dont want to give them an excuse to jack up my rates even if it was not my fault. have zero trust in insurance companies. the landlord said just send him the bill.
damnadodge
Topics: 26
Images: 72
Postby damnadodge [OP] » April 9th 2016, 1:55am
the problem really is finding someone who knows how to get the window in the existing frame. the only replacement ones i have found are the wrong size.
damnadodge
Topics: 26
Images: 72
Postby Lumpy » April 9th 2016, 2:01am
damnadodge wrote:
...the landlord said just send him the bill.
CargoCrawler might have some ideas. He installed some similar windows in his planter box.
Postby Davo2530 » April 9th 2016, 3:42am
I have had several glass claims and it has never caused a rate increase, at least check it out to know for sure. Especially since you are up against it to find a replacement window. You don't have to file a claim to get information from your insurance company.
Davo2530
Years of Membership: Davo2530 has been a member for 5 full yearsDavo2530 has been a member for 5 full yearsDavo2530 has been a member for 5 full yearsDavo2530 has been a member for 5 full yearsDavo2530 has been a member for 5 full years
Topics: 20
Alias (AKA): Dave
Van Model Year: 2002
Extra Info: 186kmiles
Postby Lumpy » April 9th 2016, 4:30am
It shouldn't be YOUR auto insurance company that's paying the claim. It should be the property owner's liability insurance (or his out of pocket, apparently as he's offered).
Postby RECox286 » April 9th 2016, 6:29am
IIRC... Look closely at the rubber gasket that holds the glass into the sheet metal. There should be
an insert (separate piece that works almost like a zipper) that expands the gasket to hold the glass
tight in the hole. Examine the bottom profile around the middle. The white stripe should be jointed
and you should be able to remove it from the gasket with a pick. After the "zipper" is out, the glass
shouldn't be too difficult to remove. Putting it back together is just as simple, especially if you slather
some plain Goop or Go Jo on the entire gasket first, then insert it into the sheet metal, followed by the
glass, and finally the "zipper" to expand the gasket. At least that is how it worked on my old full sized
vans. If you are having difficulty finding the right sized glass, try any glass shop, or auto glass service
like Safelite, etc.
Uncle Bob
RECox286
Purple Status (L6)
Purple Status (L6)
Topics: 40
Alias (AKA): Uncle Bob
Extra Info: RWD V6 [325K mi]
Postby 97cargocrawler » April 9th 2016, 8:57am
I'm not sure exactly how the glass is replaced, you may need to remove some of the riveted channels.
You might check out
http://www.crlaurence.com/crlapps/showline/default.aspx?GroupID=21889
They may either have an complete replacement or just the glass...and maybe even customer service telling you how to go about it.
97cargocrawler
Topics: 42
Alias (AKA): KING OF OVERKILL
Postby damnadodge [OP] » April 10th 2016, 2:06am
i checked with crlaurence and they did say the glass could be replaced. they said the frame is clamped together somehow............so bob, if i remove the outer part of the frame that is between the aluminum frame and the van, the glass will slide out? wont that remove the entire assembly from the van?
damnadodge
Topics: 26
Images: 72
Postby RECox286 » April 10th 2016, 3:45am
I kid you not when I say I only have had experience with the gaskets when I used to do my own glass work.
I never had to deal with the style window you are showing. If it is the "zipper" style profile, then the whole
ball o' wax will come out as one piece. You may want to involve Safelight, as they have a lot more experience
factor with glazings. Have you determined whether or not it is indeed a "zipper" profile ? It is real difficult to
look at the pics from way over here where I'm sitting and be able to guess about (???) details.
Uncle Bob
RECox286
Purple Status (L6)
Purple Status (L6)
Topics: 40
Postby redfury » April 10th 2016, 5:02am
It may be as simple as a bunch of screws holding it together. That's the way they do a lot of windows on fiberglass toppers. It's an aluminum 2 piece design...inner and outer sections. You probably just have an insert hiding the screws.
redfury
Firing on 8 Cylinders (L3)
Topics: 53
Images: 13
Extra Info: LT 5.7L 4wd
Postby damnadodge [OP] » April 10th 2016, 9:15pm
bout ready to find out in a couple of days, going to drive it over to the glass guy tomorrow. all i had was pics to show him last time. said he was not sure, but he did say he thought the cllaurence guy was full of it and it was not clamped together. we'll see......i'll let yall know how that bad boy comes apart one way or the other.
probably end up doing a mod job myself so he can put the glass in, but sure would like to know how that bad boy comes apart before i get out the sawzall, blow torch and bumper jack :D
thanks
damnadodge
Topics: 26
Images: 72
Postby sixsix » April 11th 2016, 1:44am
Like RECox alluded to - it should not be that difficult to figure out. I think it's that white filler strip - they join at the top.
( some of the shots are oriented funny ).
Seems like the same window "style" used to form enclosures around Machine Tools.
Pulling the "Filler" strip allows enough room for the rubber molding to compress, allowing it to move past the sheetmetal.
Generally to the outside.
Mike
So only CAL, ILL & NY Elects
Firing on 6 Cylinders (L5)
Topics: 38
Images: 1320
Postby damnadodge [OP] » April 11th 2016, 1:56am
not following what you mean by 'shots'.
damnadodge
Topics: 26
Images: 72
Postby sixsix » April 11th 2016, 2:11am
By "Shots" - I should have said Photos. Seems there are a couple upside down and I was going to say bottom, when in fact it was top.
Photo orientation has been a hot button issue here lately. I also did not mean it would be too difficult for you - just maybe give it a longer, closer look - it couldn't hurt to poke around at it a little :poke: with a plastic poker or non scratching implement.
It's already Broken...
Mike
Topics: 38
Images: 1320
Postby damnadodge [OP] » April 11th 2016, 2:55am
true. bout to find out pretty soon.
damnadodge
Topics: 26
Images: 72
Postby tedanderson » April 12th 2016, 1:03pm
damnadodge wrote: i did not file a claim with mine because i dont want to give them an excuse to jack up my rates even if it was not my fault. have zero trust in insurance companies.
I know what you mean. I called the insurance company to get a quote on the Safari the day that I got it. My rate was one amount. Then before the phone call ended, they asked me, "How did you hear about us? Why did you choose us?" I told them that I got crashed into by one of their policy holders and their company treated me very well in the claims process. The next day my rate changed. :(
But I hope all goes well. Anyone in the auto glass business who doesn't know how to fix that window definitely knows someone who does.
tedanderson
Topics: 76
Alias (AKA): 2Big4aMiniVan
Postby damnadodge [OP] » April 16th 2016, 2:13am
see, thats what i'm sayin! thanks tedanderson......fine example sir! i trust an insurance company about as much as i trust an electrician with scorched eyebrows.
damnadodge
Topics: 26
Images: 72
Postby damnadodge [OP] » April 16th 2016, 2:28am
alright....here goes. i got the window out and took it to the glass guy, be done in a couple weeks, gotta send off to get glass made. the way this bad boy comes out is you have to unscrew about 15 screws on the inner aluminum ring that is screwed to the frame from the inside. then it just shoves out to the outside. the plastic white subframe ring that goes around the black frame is actually part of the frame, kinda mounted to it. it all comes out as one piece. what you have to do to get another glass in there is remove the two screws on both sides of it that hold the cross bar in, then cut another split line/seam at the bottom to take it apart. the existing seam at the top is held together with 4 screws that go thru a 5 inch brace (in pic). according to the glass guy you cannot pry it apart enough to get another glass in without cutting another seam at the bottom. it was just meant to be replaced as one with the frame and all.
55170551625515455146551305512255114551065509855090550825507455066550585505055042
damnadodge
Topics: 26
Images: 72
Return to Uncategorized
It is currently February 28th 2021, 2:00pm
Uncategorized Forum
Attached by: icebrrg3rd
icebrrg3rd
in Uncategorized
Comments: 2995
Date: Feb 23 '21
Time: 6:27pm
in Uncategorized
Comments: 16418
Date: Feb 16 '21
Time: 8:08pm
Coronavan
in Uncategorized
Comments: 235
Date: Feb 14 '21
Time: 4:06am
Upstatevanvibes
in Uncategorized
Date: Feb 14 '21
Time: 3:20am
Coronavan
in Uncategorized
Date: Feb 14 '21
Time: 1:18am
