Control Arms and More
1 reading
3K views 14 replies 6 participants last post by  Yo_bear
#1 ·
The rundown:
2004 RWD Safari w/~150k miles, in need of some intense TLC. Daily driver and Forest Service road adventurer.
Me: longtime lurker, first time poster, minimal mechanical experience/knowhow but access to a large assortment of tools, this website & YouTube. Have browsed many other postings and know a lot of this has been asked before and I am working my way through comments.
To the point: I was told by a mechanic that my control arm bushings were shot and so the control arms need to be replaced at an estimated cost of $1870. Among other things he quoted me $74 for a tail light, so I won't be using his services but I'm not sure how to proceed.
My main concern is would someone in my position be better off replacing just the bushings, the entire control arm assemblies(and doing both upper and lower?) or leaving this to a professional? I don't want to get in over my head although I am keen to learn working on my vehicle.
Also if it makes sense to do tie end rod / idler arms / whole front end assembly at the same time? I have seen kits on RockAuto but if there's a recommendation on one I'd love to know. At 20 years I assume many components are ready for replacement but can't accurately gauge their durability.
Other jobs that need doing:
Rear rotors and pads. (Gonna tackle this weekend)
Replace sway bar bushings(or entire assembly, from browsing seems a Dorman replacement bar is recommended)
Replace Shocks. (From here the rear shocks seem to be an "easy" job while the front could be a pain) I am also wondering if I need to replace the spring as well as shock up front?
(Mech quoted me $467 for front/ $650 rear)
Re-installing a Parking brake(my years in flat Florida saw my mechanic rip out a broken parking brake as opposed to replacing, but living out PNW way now I feel mighty naked with all these steep driveways around.)
Other jobs advised by mechanic(but not currently in my scope of consideration)
Transmission mounts are "shot" $209
Valve cover gasket leaking $541
Diffy Service recommended $140
Transmission flush $401
Sorry for long post, just trying to be as detailed as possible for anyone who has the time & interest in advising an unsure mechanical novice.
Any input/advice is welcome and appreciated
Spot the Wandervan
#2 ·
Replace the entire control arms... save yourself a ton of labor!
New bushings and ball-joints already done for you.
Buy them online
I have done my entire set both sides, uppers and lowers.
You'll need a ball-joint separator (pickle fork) and BFH
Wow.. looks like your "former" mechanic sure knows how to RAPE a customer!
Run.. never look back
#3 ·
Mmusicman, I've seen your posts in other threads and greatly appreciate your advice!
Will look into a pickle fork(universal size?) but luckily have a few BFHs handy😂
I reckon it makes sense to do all front end stuff in one go: Sway bar, Idler Arms, tie rods, probably something I'm forgetting, any other specialty tools needed for these?
Many thanks!
#4 ·
As Mmusicman stated....replace complete control arm assemblies. It is on ly a few $$ more and way less work and frustration.
Many of the tasks on your list are not difficult. It dies take some patience and careful attention to how things fit together. A phone camera can be a wonderful tool. Take lots of pictures for reference when putting things back together. Better too many pictures than not enough.
Many of the special tools can be borrowed from local parts houses.
Pullers, picklefork, pressure gauges, even some special wrenches.
Check out O'Reilly, Autozone, and others.
Where are you located in the PNW?
Rod J
Issaquah, WA
#12 ·
Rod J
Issaquah, WA
Rod thanks for your reply and info. I will definitely be taking too many photos!
I am in Portland OR for the time being, loving exploring the mountains out this way.
WOW, control arm bushings for 2 grand a set? Rear shocks for $850? They must be damn good shocks and bushings.
I'd do them all day long for that price.
Seems like your mechanic is a little on the expensive side.
Control arm bushings are not bad, but they still suck. As stated, just replace the entire control arm.
Nice thing is they come complete and ready to bolt in as MM said.
Big question is, How long are you planning on keeping this van?
If you're like the rest of us, a very long time.
If that is the case, start replacing the important stuff first, suspension, brake components etc.
Then work your way through the lesser items of importance.
Oil and filter, trans fluid and filter (skip the flush), differential oil change.
You can do these anytime, unless driving daily, then make these a priority.
At 150K, that bad boy got a long way to go.
Nothing bad towards your mechanic, but you may want to verify that all of these parts actually NEED to be replaced.
Suggestive selling seems to be rampant lately and some of those parts may not actually be on your critical list, if on your list at all.
New to me 5 years ago, I've put ~80k on this odometer criss-crossing the country and want to put at least 80k more!
It is also my daily driver for now, so will consider the fluids higher priority. Thanks for the input!
#6 ·
GM does not recommend flushing the transmission just drop the pan clean it out then replace the filter. make sure you get the seal out from the old filter as they tend to get stuck up in the hole. Rock auto has most of the parts you listed. The trans mount is easy lift the trans with a jack and a piece of wood between the trans pan and the jack. diffy service is also easy get a drain pan remove the bolts to the cover with the pan under it then use a screw driver to pry the cover off. clean out remaining oil with your hand then clean both the cover and the rear end gasket serfices add new gasket or use RTV put it back together . on the front of the assembly there is a square hole that fits a rachet remove this plug to fill.
#7 ·
#8 ·
I don't recommend RTV for differential covers (or any covers).
Removal later will be a major pain in the ***.
Differential gaskets are cheap (about $6 or so).
Clean flat surface is vital.
Always put them on dry (as instructed).. I've never had one leak in decades.
  • Like
Reactions: Yo_bear
#10 ·
I have been using CopperCoat for decades.
Sparingly spray it on "certain gaskets" if desired (depending on surface)..
Head gaskets for certain (last time I only did the block side.. gaskets were coated)
#11 ·
Much gratitude for everyone's input!
Browsing RockAuto for complete Control Arm replacements now. (Mevotech's greasable model for $30 more than economy makes sense to me unless someone feels strongly it's unnecessary?)
Obviously pricier than I was expecting for bushings so I may try to parse out the upgrades planned but is there any job "has to" be done same time? In mind now are front shocks, sway bar(possibly just bushings), tie end rods or idler arms? Unless there something more pressing to tackle first?
Pics for those interested.
Ftr, estimates came not from my mechanic (I've yet to find someone I trust out here) just a shop with a "free inspection" included in their oil change price. I knew from that tail light estimate they were gougers and never considered letting them work on my rig. I have previously, and will again, change my own oil but I was in a bind, w/o tools, and so went to a shop based off Google😂
#15 ·
Thanks! I got pretty lucky with this van I know. Best vehicle purchase I've made thus far.
I'm looking at kits too but many seem to include extraneous components, like ball joints that I think are already a part of the control arms themselves. I will continue browsing though. Anyone recommend for/against partsgeek.com or carparts.com?
