Front body bushing
1 reading
2K views 7 replies 4 participants last post by  baily144
#1 ·
I went replace the front body bushings and found the frame had rusted out big enough to allow the bushing drop into the frame. I have rigged it up enough to work for now... What can I do to repair it? Also the rad support is all cracked and rusted out. How tough is it to take/replace the rad support? I got all the other four body mounts out ok. The front is pretty bad. Alex's
#2 ·
1/8 inch plate steel. Put the hole in it sized for the body bushing. Inside the frame. Put the old bushing back in to hold it in. Weld er up. Then put the new one in.
Rad support needs cut out and weld a new one in. Fender hood off then drill out the spot welds.
Some angle iron and a welder may be able to patch yours. It is totally hidden it aint got to be pretty. Unless your anal about that non sense like me.
Oh nobody will ever see it but I would know. And it would drive me crazy.
