I turned the key and it started up for the first time in maybe a couple of weeks. It ran well for the first 2 minutes until the engine warmed up a little.
Then I heard occasional misfires and then they began more frequent and I turned the engine off. A few hours later I started my Astro and it did the same things as before.
I used my scanner and it showed P1351 and P0300.
Almost a month ago I decided to do some preventative maintenance on my Astro and changed the spark plugs (ACDelco Iridium) and wires and then my van wouldn't start. I installed a new ignition coil, ignition control module, fuel pump, distributor, cap and rotor.
I know how to do some "remove and replace" things but it takes me about 10 times longer to do than many people. I am not good at diagnosing problems.
Any suggestions on why my Astro is misfiring or what to try first?
