I heard that the optimal engine temp that should always be is 91C but I'm never getting this temperature. The gauge usually points around 60-70C (a little more than half way between cold and 91C) during the warm seasonal temperatures. Now that its cold, I see that the gauge doesn't even go up half way (almost half between cold and 91C). I've noticed that the temperature never goes to 91C for a long time ago too and I had my thermostat changed more than a year ago. After changing it, when the engine was running for a while and was warm, the temperature still didn't go up to 91C (around 70-80C range). It's not until the mechanic was revving the engine higher in park until the gauge showed 91C-100C and started cooling down. My question is, is the temperature supposed to be at 91C under normal operating conditions when the engine is warmed up, or does it only go to 91C after high revving when the engine is warm. During normal driving, I don't think my temperature ever goes close to 91C (only 60C-75C) and now during the winter it's lower than that (40C-50C)- on average. Is this normal? Why do I never see the gauge closer to 91C? I think this might be why my highway driving gas consumption never goes above 450KM per tank.
