There are four hoses coming out. I seem to get zero heat from the unit. I have not put a hand on any of these lines when the engine was warm. Is there a heating coil in there? Is it only AC? THe unit is all the way in the back near the rear double doors, Driver's side.
Can anyone help me figure out which are AC? They all end turning up to metal as they got closer to the front, two with 90 degree bends just aft of some weird thing (emissions?) with an electric motor(?), joined by one of the other two to make three that then go over the transmission from driver's side to passenger, then go forward under the passenger's side rail tight together (metal), the fourth line goes forward next to the metal brace that runs from bell housing to transfer case on the AWD, drive's side, and then turned upward (metal too at this point). I could take the doghouse off maybe to see where that one went, but I could not figure it out after climbing under the vehicle and looking there, and trying to look down inside the hood to match the lines.
A diagram I missed searching? Could a bypass or other vacuum powered ding-dong be why I keep getting P0303 and P0300 codes?
Where does this thing with the 6 coolant lines live?
15-5551 ACDelco 15-5551 GM Original Equipment Heater Bypass Valve
https://www.amazon.com/dp/B000C9DDKS/re ... lybVVYABE2
Where does this thing with what look like two coolant lines attaching live?
ACDelco 15-5586 GM Original Equipment Auxiliary Heater Water Shut-Off Valve.
What is the 600-104 Dorman part "sitting on top of it" with two vacuum lines?
in this link:
viewtopic.php?f=34&t=107721&p=1079425&hilit=rear+heat#p1079425
Please be gentle I have been chasing my tail, but have not looked at the cooling system very closely. I mean it should be easy to find and see where 6 coolant lines converge. Plus two others. And the vacuum lines.
in this link:
