Ok so pretty much i've had several problems in the past with my turn signal switch. The first time i took off steering wheel and everything cleaned the contacts and then the lever broke on me once. I replaced it and it worked fine. 2 years later i'm driving on freeway i turn signal to the left and it feels a bit loose its not doing the click sound. so next time i make a left i push it hard downward and i feel like something broke. lol ughhh it's the 2nd time i do this but this time the "lever" that includes cruise control and wipers/washer works fine only thing is that the the "lever" holds on to "this component part i don't have a name for it" i don't know what it's called but when i push it up or down it doesn't click. I think i broke it. :/ is there a way to replace it without removing the front part of the steering wheel? lol also what's that particular part where the lever connects to.. it has a hole in it so u can manually put the lever inside.. this component moves up and down.. anyways anyone with some knowledge i would greatly appreciate it. thanks!
